Identify this MEMCAL?
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
I was cleaning up some old parts and came across this MEMCAL.
I've done quite a bit of searching online and can't seem to identify the broadcast code.
The side of it reads: 68767 91 45N --which I believe means it was out of a 91?
Top of it reads: 014 045915
Knock board reads: 3J1314
Any thoughts?
Any thoughts?
Re: Identify this MEMCAL?
That's been reprogrammed and the OEM BCC sticker removed. I put and adapter on them and if they pull code 42 you'll know it's not V8. Otherwise, you can try and run to pull a scan ID? However, that could have been changed when re-programmed.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
It is a 3.1L na or turbo the second digit of the knock board gives it away.
Engine: Lb9
Transmission: M20
Engine: Lb9
Transmission: M20
The cylinder select for the netress is incorrect if I take it you are using this as a v8.
The firmware and the fire rate would be incorrect.
88SS6SPEED
Nov 11, 2015 07:05 AM
Linson
Sep 21, 2015 01:08 PM
