Won't shut off
Car: 54 Chevy Sedan Delivery
Axle/Gears: 3.73 posi
Won't shut off
Anyone ever have a ECM cause the engine to not shut off with key. I already eliminated the alternator, unhooked it completely still runs on can unplug ignition switch same thing. Pulled all fuse except ones needed for spark, fuel, and computer still runs on?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Won't shut off
2 things would need to get power the accessory power to the ecm and the distributor switched power. Or if your saying its deseling check your base timing and the ecm accessory switched power. You don't state what ecm you are using so I can't say what pin to check.
Re: Won't shut off
Won't shut off at all runs great. Using 1227730 ECM it seems to me like once the engine starts the ECM keeps feeding power to coil and fuel after you shut off the ignition switch won't die till you pull coil, fuel or ECM fuse. With out starting the engine power to ECM switches on and off with key like it should but once I start it there is power all the time
Engine: Lb9
Transmission: M20
Re: Won't shut off
A6 on the ecm goes to switched ingintion source , check to see it that has power when you turn the ignition off.
Engine: Lb9
Transmission: M20
Re: Won't shut off
Re: Won't shut off
I know but after the engine is running it will stay energized after the switch is off till I kill it by pulling coil wire or ecm fuse then the power drops off. it's like the altenator is feeding the system after switching off but I have disconnected the alt and it still does it so it is getting power from somewhere else
Re: Won't shut off
any relays that you can think of that might go bad and cause a back feed thru the sytem?
Re: Won't shut off
is it possible for the ecm to back feed power to the inginition thru fuel pump power. Car wiil shut off and run fine if I do one of 2 things, 1. un plug fuse to fuel relay (slow start due to having to build oil press) 2. unplug oil pressure switch and just use relay, if both are connected the engine will not shut off with the key.
Car: check
Engine: check
Transmission: check
Re: Won't shut off
There is something wired wrong. At key-off the ECM stops firing the injectors. And, power to the ignition coil is turned off.
So it sounds like there is still power to the IGN+ side of things that is keeping the ECM & engine running.
RBob.
RBob.
Re: Won't shut off
yes thats what I'm trying to figure out. If I run on just the relay or just the oil pressure switch it shuts off just fine but with both of them connected like factory schematic for 92 it wont shut off run good for 2 years till out sat outside and a rain shower came thru went to pull in garage and would not shut off was wondering if possible ecm fried from moist.
Car: check
Engine: check
Transmission: check
Re: Won't shut off
RBob.
Gunner242
Dec 25, 2015 04:49 PM
