Does this chip come with Vats?
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
I'm having a problem with my car just cranking and not turning over. It is an 89 GTA originally had VATS but got a chip to disable it and it started fine but ran like it was in limp home mode so I changed the ecm to the same type I had in my car but I think I fried the new chip so I decided to get a stock memcal with chip from an 88 Trans am with the code AKFX 2427 because I thought that one didn't come with VATS but when I try to start the car it just cranks and doesn't start like what it used to do before I got the bypass chip. Did this chip come with VATS?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Does this chip come with Vats?
Akfx
Options:
With GM3 AXLE, REAR, 3.45 RATIO
With LB9 5.0L GAS 8 CYL MFI HO
With MK6 MAN 5 SPD BORG WARNER 2.95 1ST O/D
With NA5 FEDERAL REQUIREMENTS
Without UA6 THEFT, DETERRENT SYSTEM
Options:
KO1
16
Oct 15, 2015 05:00 PM
