Need some help.
Car: 1988 Camaro
Engine: 2.8L V6
Need some help.
Hey thirdgen members,
I have a 1988 Camaro I've started to notice that my car is running VERY rich,
So rich in fact I just changed my oil and the bad oil actually reeked of gasoline(literally). I would like to know if someone could be so kind as to
tell me where my cars O2 sensors are and what other sensors it could be.
Car: 90 Iroc Vert
Engine: 5.0L
Re: Need some help.
On a V8 run rich is a number of things, TPS, O2 sensor, ECM.
If your oil is gas saturated, you might want to fix the problem very soon. The gas will eat the rings and you will be scoring cylinders in short order.
Car: 90 Iroc Vert
Engine: 5.0L
Re: Need some help.
02 sensor is usually in exhaust manifold, that interacts w/ecm and regulates fuel delivery, but doesn't begin to work until it get to 600 degrees F. If its in/op ecm goes into a default mode and runs lean.
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Need some help.
Probably CTS or leaky injector. Check your spark plugs for signs of raw fuel
Car: 1988 Camaro
Engine: 2.8L V6
Re: Need some help.
sorry for reviving a old thread I found out that it was the O2 sensor, but to be safe i changed the spark plugs and the spark plug wires.
Elephantismo
Feb 13, 2019 12:51 AM
