Need ECM for 1982 Trans Am with Crossfire Injection
Old Jun 24, 2013 | 11:20 AM
82tarecaro's Avatar
I finally diagnosed my non operable hood louver and tracked it to the ECM. If I jumper the relay, the flap opens, but I have no signal from the ECM. I tested the wire for the hood louver at the ECM and nothing.
What are my options here? My local parts guy sells a Cardone rebuild, but I am not sure if I trust it.
The 83 computer seems like it was an improvement, but I would also have to find a PROM.
Is it possible to repair these computers? I know I was able to repair a Ford computer once, but there is no info online for this one.
Everything else involving the computer is fine. Not the fastest computer, but the car runs good.
Old Jun 24, 2013 | 01:44 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Need ECM for 1982 Trans Am with Crossfire Injection
Most likely as quad-driver failed. They fail due to a solenoid or relay coil shorting out. Before replacing the ECM be sure to check the resistance of the various devices controlled by the ECM's q-drivers. Such as CCP solenoid (if present), EGR solenoid, AIR pump solenoid(s), and TCC solenoid.
As long as the q-driver didn't burn a hole in the PCB they can be replaced. Look for 16-pin DIP packages near the harness connector. If bad, 99% of the time they have physical damage.
RBob.
Old Jun 24, 2013 | 03:08 PM
82tarecaro's Avatar
Are they all controlled by the same driver?
Old Jun 24, 2013 | 04:41 PM
dangerboy's Avatar
Car: 83 Trans Am
Engine: 350 Carb'd
i have a complete wiring harness and ecm out of an 83 ta. i also have the under the hood components. let me know if you need anything.
Old Jun 24, 2013 | 04:50 PM
82tarecaro's Avatar
I sent you a pm
Old Jun 24, 2013 | 05:21 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I don't know. A quad-driver has 4 outputs, but GM will double up some. This way a TCC solenoid is driven with 2 of the 4 outputs. There may be two q-driver chips in the ECM.
There is good q-drvr info in this thread:
https://www.thirdgen.org/forums/dfi-...77302-ecm.html
Pic's and all....
RBob.
Old Jun 24, 2013 | 06:55 PM
82tarecaro's Avatar
I opened up the computer to see if there were any burnt chips. There were none. I tried tracing the pin out on the board to a 16 pin chip, but the first chip it hits is a 9 pin chip with a metal heat sink on top of it - which looked fine. Unless there is a short on the board, none of the chips look burned. I am going to try to acquire a used computer to swap in to see what happens. Still runs fine, so not the end of the world. It has been like that for as long as I have owned the car which is like 24 years. I have never heard that flap open.
Old Jul 28, 2013 | 03:22 PM
H2Oskeefreek's Avatar
I have an entire crossfire setup I'd sell if you are interested. complete with all computers and wiring.
Old Jul 28, 2013 | 08:45 PM
82tarecaro's Avatar
Thanks - but I finally got my hands on an 83 ECM and put it in the car. I haven't been able to take her for a ride due to weather but she seems to start and idle better. The hood louver also works in diagnostic mode now so I am assuming it will work at WOT. I have to take her for a cruise later in the week.
Old Dec 21, 2019 | 12:44 PM
coxboy's Avatar
Car: 1982 Trans Am
Engine: 5.0 Crossfire
hi so you solved by replacing with a 1983 ecm?
Old Dec 21, 2019 | 03:49 PM
82tarecaro's Avatar
Yes
the 83 computer is a direct swap and the car runs better. Both are not easy to find but if you are trying to find one, try to get your hands on the 83 ecm.
Old Apr 3, 2020 | 10:24 AM
8284Camaro's Avatar
Car: 1982 Camaro z28
Engine: 305 CFI
Transmission: 200M
Hello, I have a 1982 Z28 with Crossfire and my hood louvers recently stopped working. I find this thread very useful. I was wondering where the relay is located for the hood louvers so I can try and run some tests.
84z96L31vortec
Aug 20, 2017 12:16 AM
toronto formula
Nov 10, 2015 06:17 AM
Reddeath210
Oct 6, 2015 08:20 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
3rdgenparts
Aug 6, 2015 09:03 AM
