Converting a BBC with a SC to FI
Old Jun 30, 2013 | 09:55 PM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
Not quite sure where to start this thread. I have a relative who is running a carbed Blown big block and wants to convert it fuel injection. Any systems out there that would replace the duel carbs to run EFI?
Old Jul 1, 2013 | 07:39 AM
efiguy's Avatar
Re: Converting a BBC with a SC to FI
Is he wanting to run throttle bodies on it?
The only other way really is make or buy an injector block to inject the fuel above the blower, they last longer that way.
To make the best use of an EFI system he needs to make sure he gets a system with total spark control, boost control and multiple fueling strategies.
Old Jul 1, 2013 | 07:59 AM
seiplentz's Avatar
Car: 85 Z28
That was what I thought using throttle bodies but I have not seen anything like that. Could you point to a setup like that? I do want to run a full ecm controlling timing and fuel not sure about boost since it is belt driven. I am not real familiar with superchargers.
I am also curious about the injector block.
Old Jul 1, 2013 | 08:36 AM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
Honestly not a big EFI person so i could be wrong but i would think something like this would do the trick.
http://www.summitracing.com/parts/fst-304150/overview/
Old Jul 1, 2013 | 08:44 AM
seiplentz's Avatar
Car: 85 Z28
That is exactly what I was thinking of doing. But wasnt sure if I could run 2 of them or 2 of them with 1 ecm.
Old Jul 1, 2013 | 09:33 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Google blower efi
There are several companies doing efi plates and offering kits for efi roots blown type setups
Force-efi is one
Old Jul 1, 2013 | 09:39 AM
efiguy's Avatar
Apparently not because no it won't. Won't accept boost and doesn't have any spark control.
Accel 77135W in dual form would give you 2 750 cfm throttle bodies and total spark/boost control, datalogging etc.
Or you can buy/machine a block to hold 8 injectors right above the blower assembly and that'll work as well.
Old Jul 1, 2013 | 09:43 AM
efiguy's Avatar
Google blower efi
Force-efi is one
With all due respect, I wouldn't send my worst enemy to Rob at Force EFI. I've had to redo many of his tunes. I wouldn't let him change the oil in my lawn mower. Actually I can't believe he's still in business.
Old Jul 1, 2013 | 09:46 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I know nothing of their business just happened to find efi setups for blowers. Just a reference point to show what can be done and what parts you may need. Proceed with caution as always lol
Old Jul 1, 2013 | 03:57 PM
efiguy's Avatar
Here you go, disregard the heading. I can get it.
http://autoplicity.com/products/3250...dy_system.aspx
Old Jul 1, 2013 | 07:53 PM
seiplentz's Avatar
Car: 85 Z28
Thanks for all the help I now know what to look for.
efiguy I will be in touch if he decides to go that route. Thanks again for the help.
FormulasOnly
Jul 23, 2018 08:47 AM
okfoz
Oct 13, 2015 02:19 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
bjpotter
Oct 2, 2015 09:12 AM
vortec tpi
Pacific Northwest Region
Sep 26, 2015 08:13 AM
