Can I use another stock chip
Car: 91 firebird vert
Engine: 305 tbi
Hi I had a chip burnt but its to aggressive for my taste. Anyway I set my old one off to the side to install new. Long story short it got stepped on . I found a 91 camaro 305tbi with auto. Same as mine. Will that chip work in my car. Thanks!
Car: check
Engine: check
Transmission: check
Re: Can I use another stock chip
Yes, that chip will work. If you still have the old one check the 4-letter code on the top and see if they match. Good possibility that they will. Which means they are the same calibration.
RBob.
RBob.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Any 89-82 tbi prom definition $61 for the 1227746 ecm will work. just check the bcc to make sure its for a lo3 auto.
Genopsyde
Oct 7, 2015 08:35 PM
NBrehm
Aug 25, 2015 11:49 PM
