Dear Prom Guru's
Old Feb 13, 2014 | 02:50 AM
JacobIroc's Avatar
Car: 92 RS 25th Anniversary
Engine: 305 TBI -> 305 TPI
Transmission: T5/T56
Axle/Gears: 3.08 - 3.73+ soon
Dear Prom Guru's
I have a question.
I have a 86 MAF TPI that I am converting to SD. Now I know that the MAF and SD cars used a different Knock Sensor. However, since I am going to be tuning and will have access to constants.. Can I just change the constant that the '730 ecm expects or does this adversely affect the ESC ? thanks in advance for your input.
Old Feb 13, 2014 | 08:19 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Dear Prom Guru's
I take it you are going to use a '7730 ECM? If so the reason for the different knock sensor is that it has a lower resistance. This allows the ECM firmware to measure that resistance to ensure that the sensor and wiring for it are intact.
However, you can change some parameters for that test and have the higher resistance sensor pass OK.
RBob.
Old Feb 13, 2014 | 02:34 PM
JacobIroc's Avatar
RBob.
Ok thank you
Old Feb 13, 2014 | 02:48 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
If you want to send me a pm I can walk you through a good work around
Old Feb 13, 2014 | 08:44 PM
JacobIroc's Avatar
Will do
Old Feb 13, 2014 | 08:49 PM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/diy-...l-mod-run.html
here is the link to the parameters to change. If you do want to use a tpi maf esc email me at brianlvs@yahoo.com and I will walk you through it
Old Feb 14, 2014 | 12:03 AM
JacobIroc's Avatar
I'm using the 730 ECM and the SD 305TPI 5 speed memcal/chip you sold me. I just want to use the MAF-style Knock sensor since its already in the engine. I'm using the chip / memcal you sold me as the basis
Old Feb 14, 2014 | 05:45 AM
Engine: Lb9
Transmission: M20
You would be better off swapping the ks and using the memcal I sold you. Or you can use the tpi maf memcal. You will need to use the maf esc and wire the signal to B8 of the ecm.
I have soldered in a 3.9k resister on the memcal to make this work. I will not post all the information here about that. I have been burned bye trolls before that take things and run to ebay to make a buck. Pm or email me on the details on the resister.
Old Feb 14, 2014 | 07:53 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Hmmm, so not DIY... Moved.
RBob.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
dusterbd
Sep 29, 2015 08:40 AM
BLK87Z
Sep 18, 2015 11:29 PM
Winchester1094
Sep 15, 2015 09:48 AM
