v6 5 speed prom for t5 swap.
Car: 1986 camaro iroc z
Axle/Gears: stock
so i have serched all over the net for a prom from a 5 speed v6 92 bird so i can do a t5 swap so it wont stall. but i cant find any i dont know if im looking in the wrong place the wrong way etc. i heard i need a production number to find it in one place i dont know any help finding a stock prom chip would be amazing or if i need to change the ecm completely i guess i can do that anyways thanks .
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: v6 5 speed prom for t5 swap.
Memcal identification in done bye the letters on the prom called a broadcast code. If you are in need of a replacement memcal send me a pm
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
You should be looking for an elusive BAWX MEMCAL.
However, I already know there are people who will argue with me, but in the years I had a T5 installed behind my V6, I only had a manual PROM installed for a matter of months (because I never could readily find that HNL). With no issues, except when I switched to the newer harness (like yours with the 730), when the harness had issues. You will be just fine with the MEMCAL you have.
Engine: 2.7L V6
Axle/Gears: 4.41
For the speedo, take the tail housing off of your 4L60. Count the number of teeth on the speedo gears on both the existing VSS and the drive gear on the output shaft. You then divide the number of teeth on the driven gear (on the VSS) by the number of teeth on the drive gear (output shaft). The number you come up with is the number you will need to multiply the number of teeth on the T-5's speedo drive gear so that you will know the number of teeth on the driven gear you will probably need to buy.
For my installation, I have a 7 tooth drive gear and an 18-19 tooth driven. But you will need different gears because your car SHOULD have a 3.23 rear gear ratio in it (mine is a 3.42). Be warned that if you need to replace the drive gear (the one in your T-5 may be the red one), you will have trouble finding the purple one (which everyone uses for swaps).
Axle/Gears: stock
well mine is 3.23 so yea if i could find what gears they should be on here it ben ice since me getting the t5 has been set back a bit
Engine: 2.7L V6
Axle/Gears: 4.41
Axle/Gears: stock
so thats all i need to make this tranny work the drive gear? can i run it with the stock auto prom chip
Engine: 2.7L V6
Axle/Gears: 4.41
You need to check BOTH gears in the trans. One or the other or possibly both could be wrong.
Don't worry about the MEMCAL. It will be fine. You won't have any issues with anything provided you buy the right VSS (4L60 VSS won't fit in the T-5) and speedo gears.
Let's put it this way...
Would you rather spend...
1. X amount on the trans, Y amount on the flywheel, Z amount on the clutch parts, another $ on a VSS, more $$ on a MEMCAL you may never find, or $$$ on either a PROM reprogrammer or to have someone write the chip for you...
or 2. $$$ on the trans, flywheel, clutch, VSS, and use your stock MEMCAL and spend less than $20 on speedo gears?
BTW, make sure that when you're collecting the parts, you get a flywheel from an 88+ V6. You have an internally balanced engine and 87 and older are externally balanced (have a balance weight on the flywheel). If you buy the wrong wheel, you could shake the bottom end apart.
Axle/Gears: stock
i was thinking of getting the flywheel off the 95 with the trans clutch flexplate hydraulic lines master/slave cylinders and the pedals
