1992 ECM
Car: 92 Firebird--02 Grand Prix GTP 2Dr
Engine: Poncho 400--3.8 Supercharged
Transmission: T56 6 Speed--4T65EHD
Axle/Gears: Open 10 bolt 3.42--Internal 2.93
1992 ECM
So looking on the Oriellys website for ECMs, the V6 MPI computer has the same code (01227730) as the V8 MPI/TPI, and same part number. So my question is, knowing there is no crk sensor, are the injector banks fired by dist. pickup? I'm just trying to understand how this ECM works as a whole.
Car: check
Engine: check
Transmission: check
Re: 1992 ECM
Yes, the ECM counts the distributor reference pulses (DRPs) to know when to fire the injectors. All injectors are wired to the one driver in the ECM and fire together (batch mode).
It is the MEMCAL that is different between a V6 and a V8 application. Note that the '7730 was also used with a single 1-bbl TBI set up on 4 cylinder engines.
RBob.
RBob.
Re: 1992 ECM
RBob.
RBob.
Car: check
Engine: check
Transmission: check
Re: 1992 ECM
The MEMCAL sets the DRP count rate. This is done via resisters setting a voltage level that the ECM interprets. The counter is in the ECM hardware, not the MEMCAL.
Note that the distributor is the crank position sensor.
RBob.
RBob.
Re: 1992 ECM
So the MEMCAL makes the ECM decide which values to use essentially? By changing voltage input to the ECM? So does that all use the same counter just at a different rate?
Car: check
Engine: check
Transmission: check
Re: 1992 ECM
RBob.
