What causes the ECM to stop communicating?
Old Dec 29, 2014 | 12:12 PM
broke91firebird's Avatar
Car: 1991 Pontiac Firebird convertible
Engine: 3.1 soon to be 3.4/3100
Axle/Gears: original gears, for now
I have a 1991 Firebird Convertible 3.1L. I bought this car in November. I'm trying to get it running again but I have no injector pulse. After a bunch of searching around I hooked up the scan tool.
Not only do I not have injector pulse the ECM isn't seeing the Throttle position, RPM, neutral safety switch and it thinks the collant is -39 degrees F.
Also the check engine, battery, security are all dark. the only light on the dash that comes on is the airbag light.
All under dash fuses OK'd with a test light and Ignition module replaced.
Any ideas?
would be derfered
Old Dec 29, 2014 | 05:05 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: What causes the ECM to stop communicating?
I'd be looking for a bad ground or bad fuseable link. Something somewhere is not making the contact it should for all those problems to happen.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
skeltor
Feb 2, 2016 10:37 AM
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
Ranbo108
Sep 9, 2015 12:20 PM
