Memcal problem
Old Jan 19, 2015 | 07:33 PM
silverstang84's Avatar
Car: 88 IROC
Memcal problem
Hey guys, I think I've narrowed my
Cars weird running problem down to a bad memcal. I removed the memcal cober from my ecm, with the car running, if I tap on the side of the ECM or just barely touch the memcal, the check engine light will come on and the car will instantly run badly. There seems to be a loose connection at the memcal. But I don't know for sure. Could it be the ECM? Bad ground to the ECM? Any help is appreciated. Thanks
Old Jan 19, 2015 | 07:52 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Memcal problem
Sounds like a bad circuit board in the ecm is this a 1227165 ?
Old Jan 19, 2015 | 08:35 PM
Car: 88 IROC
Re: Memcal problem
Yes sir, it is
Old Jan 19, 2015 | 08:38 PM
Engine: Lb9
Transmission: M20
Re: Memcal problem
Sounds like its time for a new one.
Old Jan 19, 2015 | 09:22 PM
Car: 88 IROC
Re: Memcal problem
The previous owner had already changed it out once before.. Is it possible 2 have gone bad? Seems kind of odd.
Old Jan 20, 2015 | 09:17 AM
Engine: Lb9
Transmission: M20
Re: Memcal problem
I have only experienced 2 bad memcals in the last 14 years. Both have lost data and were throwing a code 51. I was able to salvage them both.
My bet would be a bad ECM. It seems like out of the obd1 ecms the 165 experienced circuit board flexing. I can test your memcal on a simulator if you want to cover shipping. I hate
To see someone throw good money after bad. I use to loan members ecms but I have been ripped off twice so I'm not doing that any more but I do have a 165 for $60 if that helps and if it doesn't fix the issue if you return it I will refund you minus shipping. Or if you put a ad in the wanted section maybe someone close will come over and let you try there ECM.
Old Jan 20, 2015 | 09:39 AM
Car: 88 IROC
Re: Memcal problem
Thanks a lot for your offer and help. I may take you up on it. The ECM in the car has a 1 year warranty from autozone, so I'm thinking of exchanging the one I have for a new one. But I'm not happy about the idea of putting another autozone computer in...
Old Jan 20, 2015 | 09:40 AM
Car: 88 IROC
Re: Memcal problem
Tuned performance, can you message me your email address? Thanks
Old Jan 20, 2015 | 09:43 AM
Engine: Lb9
Transmission: M20
Re: Memcal problem
It's brianlvs@yahoo.com
Old Jan 20, 2015 | 08:41 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
Re: Memcal problem
Tuned is the man.
Old Jan 21, 2015 | 08:15 AM
Engine: Lb9
Transmission: M20
Re: Memcal problem
Thanks Tim
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
RyanJB
Sep 2, 2015 01:27 PM
