Won't start with EPROM
Old Jan 21, 2015 | 11:17 AM
night_rider13's Avatar
92 305tbi won't start with EPROM plugged in will run with out it tho
Old Jan 22, 2015 | 08:42 AM
L98_383_Stroker's Avatar
Re: Won't start with EPROM
If the car runs with the PROM out, it prefers limp home mode. Something is wrong with the PROM or ECM. What is the check engine light doing with the PROM in? Also, try reading the trouble codes by shorting pins A&B on the ALDL connector. Let us know what you find!
Old Jan 23, 2015 | 12:43 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
KOEO measure the voltage on B6 of the ecm a dark blue wire. You should see 2.5vdv or 50hz.
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
EFR2000
Aug 18, 2015 08:54 PM
