Distributor block off
Old Mar 2, 2015 | 11:23 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Guys that have gone DIS, are you just cutting down your dizzy to keep the oil pump spinning or are you buying something special ?
-- Joe
Old Mar 2, 2015 | 11:35 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Distributor block off
http://m.ebay.com/itm/261030046838?_mwBanner=1I know the lt1 oil pump drive has a hold down so I'm not sure if it can be adapter to a older sbc.
A L31 truck cam position sensor to block the hole is another option.
Old Mar 2, 2015 | 11:40 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Chevrolet SBC Distributor Hold Down Clamp Distributor Optispark Delete Plug LT1 | eBay[/url]
I'd need something with the drive build into the blockoff.
I'm tempted to just cut down a distributor but I wanted to see if members were doing something else first.
-- Joe
Old Mar 2, 2015 | 11:46 AM
Engine: Lb9
Transmission: M20
Pete Jackson use to make a plug / oil pump drive for the sbc distributor relocation kit that was driver off the front of the cam.
http://m.ebay.com/itm/400279046045?_mwBanner=1Or yeh like this a small cap hei with the gear left on (photo of a prime tool..)
You can allways mill down the housing pin the shaft on the top were the reluctor is, cut the shaft down and instal a expansion plug upside down. Just account for distributor end play when drilling and installing a washer for a roll pin on the top of the drive shaft.
Loudnproud86
Jul 14, 2016 12:59 AM
camarohelp
Sep 22, 2015 03:19 PM
BLK87Z
Sep 18, 2015 11:29 PM
RyanJB
Sep 14, 2015 03:39 PM
Jlanz55
Sep 6, 2015 03:05 PM
