New to DFI, have a question
Old Aug 19, 2001 | 10:35 AM
GTA600's Avatar
Im building a 600 hp procharged 350 using a TPIS miniram, AFR 195cc heads 8.8:1 with 15psi boost. D1 sc with the 3core intercooler. And an Xtreme HR cam. Im going to use DFI for engine management but I dont know ANYTHING about engine management or how to read spark plugs or anything. Where is a book or something that I can read up on this stuff to get ready for the DFI, I dont want to blow up my $10k engine. Thanks guys.
Matt
87 GTA LB9
Spohn LCA's and relocation brackets
WS-6 suspension
Spohn Adj. Panhard
Spohn Adj. Torque arms 1 deg. preload
Spohn Subframe connectors
Edelbrock Strut tower brace
Eibach springs lowered 1"
KYB all 4 corners
Energy suspension bushings in rear and PST front end kit
Currie 9" 3.70 posi rear
automatic
no times yet
Old Aug 19, 2001 | 10:12 PM
black bart's Avatar
My dfi came with a manual you should get one with yours also. Read it every thing you need to know about tuning it is in there every one is looking for a short cut by copying some one else program but the best way is to learn to tune it yourself it takes time but it is not rocket science
READ READ READ
Old Aug 20, 2001 | 07:55 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
If you are unclear on how to do a full calibration from scratch then have it tuned by a pro that uses a wide band O2. If you don't, you may do some serious damage to the motor.
www.geocities.com/dzperf
D&Z Performance
"Putting Power to the Pavement"
Old Aug 21, 2001 | 11:03 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by HiTech5:
</font>
Wide bands are neat, and can save some time, but they are not by any means necessary.
I've seen alot of suposedly pros, that were at best dealing with a deck of 51.
You need to start doing alot of reading, and maybe helping out some guys running a fast car to see what things should look like (ie plug reading).
Old Aug 22, 2001 | 07:19 PM
GTA600's Avatar
The point of this room is to talk about programming...the answer shouldnt be...uh..go have somebody else do it...
Thats not what I asked.
Hopefully next summer I will be on with Atlanta Speed Shop and I can get some hands on experience. Georgia Tech doesn't really have any automotive or motorsports classes in their Mechanical Eng. program so Im kinda stuck right now just reading books. I wanted to know some general engine management material that I could pick up and start to teach myself. If anyone knows of any books I can get please let me know what they are called and the author so I can find them. Thanks!
Matt
87 GTA LB9
WS-6 suspension
Spohn Adj. Panhard
KYB all 4 corners
automatic
no times yet
Old Aug 22, 2001 | 09:13 PM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
GTA600 - The point I was trying to make is that time spent with someone who knows the programming can be invaluable. I had my initial calibration done by a local guy who taught me alot about DFI in the 2 hour period that he calibrated. His initial programming got me into the 11.90's. From there I was able to get another 2 tenths by playing with fuel and spark.
Sorry if I offended you with my reply!
D&Z Performance
[This message has been edited by HiTech5 (edited August 22, 2001).]
Old Aug 23, 2001 | 06:41 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
There are several tech articles at http://www.diy-efi.org/ . You can also go to www.cruisinperformance.com and check out the DFI programming manual. Lots of good stuff in that one. I'm not familar with any books in particular. Perhaps a search at Barnes & Nobels or something.
Old Aug 23, 2001 | 09:11 AM
GTA600's Avatar
Its my bad I misunderstood what you were saying. I get alot of people who turn their noses up at me because Im 20 and don't have much experience. My apologies.
Thanks for the links I'll check them out.
Does anyone know what all is NOT controlled by the DFI computer? I know that the Tranny Lockup requires an external controller. I have a 700r4 on my 1987. What about the speedometer or the cruise control? Are there aftermarket controllers for everything that the DFI doesn't control or do I need to get a piggy-back harness for it?
Old Aug 23, 2001 | 09:54 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I think you will find what the DFI controls varies from system to system. You will need to enquire with the various DFI manufacturers to determine what they do and do not control.
Off the top of my head, this is what the stock GM ECM (SD TPI) controls:
1) TCC Lock-Up (automatic) or Shift Light (manual).
2) EGR Duty Cycle
3) Purge Cannister Duty Cycle
4) Air Divertor
5) Fan#1 on a dual fan car (not sure about a single fan car, this may be solely by the Fan Switch much as Fan#2 is on a Dual Fan Car)
6) A/C clutch engagement/disengagement
7) VATS
8) Injector Pulse Width
9) Ignition Timing
10) IAC position
There may be a couple of minor things that I have forgotten, but that is basically the "devices" that the Stock ECM controls on an SD TPI car. If the DFI is designed to be "emissions compliant", then the EGR and Purge Cannister would be controlled. But if the DFI is designed for "off-road use only", you may find a lot of the emissions equipment is not supported.
Old Aug 31, 2001 | 08:19 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
i dont know jack about DFI, but i know that your speedo is controled mechanically from a gear in your transs and that cruise control is operated by a vacume system, neither of them are DFI controled as far as i know.
Old Sep 1, 2001 | 09:14 AM
RCR's Avatar
RCR
I made up a little relay circuit that allows my Accel DFI to lock-up the TC. It's pretty simple.
Also, if you're doing the work on the GTA, the speedo is electric, but the ECM does not control it.
[This message has been edited by RCR (edited September 01, 2001).]
Old Sep 14, 2001 | 02:21 PM
86 IROC's Avatar
I have an Accel DFI unit in my car. Batch fire, the basic $800 harness/computer set up. I have a friend that knows quite a bit about the Speed Pro system, and he successfully campaigns a car in the EZ Street class. He knows fast cars, has a job in IT technology, and is overall sharp when it comes to these things. I'm more adept when it comes to mechanical stuff, engine combinations, gear ratios, etc. I'm hoping that between the two of us - we can get this thing to run right. The harness/computer I have, was bought from a guy that bought a complete SR kit - then he decided he no longer wanted the DFI computer and harness. So, I snagged it for $500 - brand new in the box. I have no such manual for programming clues & tips. I have an installation manual. But, that's it. I see a link in this thread for a manual, would that help me?
1986 IROC, fully loaded, Mini Ram'd 383, Art Carr 700R4, Accel DFI, 12 bolt rear, etc, etc......
Old Sep 17, 2001 | 01:55 AM
PROCHARGED89Z's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Grumpy:
</font>
Check out my Hompage,or the beginnings of one.355 dynoed at 400HP at 5800RPM & 410LBFT of TQ,on Motorhttp://www.procharged89z.cz28.com/index.html
Old Sep 17, 2001 | 02:10 AM
</font>
I agree Grumpy.I had a talk with the shop that sold me my Tec 2 and said it is nice the wide band but not at all nessary,ego gives the same results.I run a Tec 2.
GTA I wrote out a big reply but for some reason it didnt show.Here is some links to get you a feel for my program and system.Go here and download the use manual to get a feel for the Theory behind the Tec 2s programs,it is much different than other aftermarket systems.
http://getfuelinjected.com/tec2.htm
Here is another link to the newest version of their software,download it to your desktop and install it and now you can atually see how the system will work.Alot of features.Go to the Tuning wizard and you can type in a engine and it will generate a startup program to get you started.At anytime you are unsure about a parameter hit F1 and it will explain it and some tuning hints too.Here it is:
http://getfuelinjected.com/WinTEC2/
Here is the site for the system so you can get anover view of it:
http://getfuelinjected.com/index.htm
In my opinin this is a very good system for the money,complete engine programming and crank triggered ignition in one.all the sensors come with the kit(except idle air and knock sensor)Comes with the crank trigger,and sensor.It is dead on acurate the timing.The throry behind the system is much different than other aftermarket system,just read the Tec 2 manual to get a grasp first and antyhing else let me know.
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
marcusaw
Aug 10, 2015 08:13 AM
