92 z28 MAT sensor isn't where it should be
Old May 18, 2015 | 03:25 PM
katula's Avatar
My Chilton's said my MAT sensor should be in the rear of my intake where the bolt for the tubes run but its not there there is a sensor under the intake wondering if that's it. It is on my 350 tpi
Old May 18, 2015 | 05:22 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Re: 92 z28 MAT sensor isn't where it should be
Old May 18, 2015 | 05:26 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
If you mean the air temp sensor, then yes. That guy looks kinda like a temp sensor that is on the rear underside of the plenum.
Old May 18, 2015 | 06:56 PM
ULTM8Z's Avatar
That's the MAP sensor being depicted in the photo. It measures pressure not temperature. The MAT sensor is on the under side of the plenum. It's a brass body with a NPT threaded end that screws into the bottom of the plenum.
Old May 19, 2015 | 02:12 PM
katula's Avatar
That's what I was thinking my Chilton's said it was on the opposite side of the mapin one of the bolts holding the tubes to the plenum I seen the sensor underneath that I figured that's what it was but wasn't sure Thanks
Old May 19, 2015 | 02:39 PM
katula's Avatar
Nice engine greenyone
Old May 19, 2015 | 06:41 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
HA! That's a google search photo. Mine is new and clean, but doesn't have the Captain America paint job.
jaridjohn
Jul 8, 2024 03:49 PM
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
timonator
Aug 11, 2015 09:56 PM
