need help w/ dfi install
Old Oct 22, 2001 | 08:34 PM
nice3rdgenz's Avatar
i purchased a dfi system from a guy, it has the wire harness and everything. i was wondering if i need to move pins in my stock wiring harness to make the new computer work. any advise would be a great help
thanks dennis
91z28 350tpi auto runs 14.3
Old Oct 23, 2001 | 07:48 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
Dennis,
If it came with the harness, you would use that in place of the existing harness, (unless it plugs into the existing harness.) Or you can do what I did, repin the existing harness. The first thing I would do, is get the wiring diagram for your existing harness and the DFI. Compare the two and see what is different. If you have more ?'s, post or email me.
Bob '89 Ram Air Formula 350
And until that time when death won't wait, let each man rage against his fate. (O'neill)
My car's homepage
Rider's Ride
Old Oct 23, 2001 | 12:26 PM
i does fit into the stock harness, so i just need to move some pins. you dont happen to know where i can get a stock wiring diagram. the one in my haines manual is only for a maf car. if i had that i would just read on the dfi plugs on what pin needs to be where right..?
Old Oct 24, 2001 | 09:06 AM
RCR's Avatar
RCR
No, someone else might be able to help with the schematic. The only one's I have are for MAF's (85 & 88).
Yes. You could just match the pins. My question is why do you have to change pins around if the harness is meant to plug into the factory harness? Unless it was meant for a different application.
Old Oct 24, 2001 | 09:32 AM
i have to do what you did, just repin the stock one so that it will work with the dfi computer..
91z28 350tpi auto, runs 14.3... aim screen name nice3rdgenz
Old Oct 24, 2001 | 10:01 AM
or do i need a harness thing from like white racing to go in between..
Old Oct 24, 2001 | 04:20 PM
RCR's Avatar
RCR
You could do either. If you want to change back for some reason, then the interface would work and be easy. If this is permanent, then re-pinning would be better. The only problem you have now, is getting the pin-out of the factory ECM.
Old Oct 25, 2001 | 12:26 PM
88SS6SPEED's Avatar
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
You can find a copy of the harness pin out on the www.mrgasket.com website, click on ACCELL/DFI manual and the PDF file has what you need. HTH's Here is the DIRECT link
http://www.mrgasket.com/ftp/pdf/EMIC.pdf
88 Monte SS 355 TPI/LT-4 HOT CAM/Fully ported 1990 Corvette L-98 heads/AFR Hydra-rev/ T-56 6-Speed/ PRO-5.0 shifter/ 1-3/4" full length headers/3" X-PIPE assembly/ 8.5" G-80 rear with 3.73 gears.
http://community.webshots.com/user/ssynergy
www.y-t-g.com/88monte
[This message has been edited by 88SS6SPEED (edited October 25, 2001).]
Old Oct 26, 2001 | 10:18 AM
do u know where i can get the pin locations for the stock ecm. the guy i bought the dfi from sent me the pin list from accel. (the same one at that website)
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
marcusaw
Aug 10, 2015 08:13 AM
