DFI programming information swap page
Old Nov 2, 2001 | 11:57 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
Is anyone interested in contributing to something like this? We could all post our mods and our latest programs so everyone could look at them and maybe learn from each other. I'd be glad to host it. Just wondering if there was any interest.
thanks
Dan
87 IROC-Z, 6.7 $uperram & cam, Eagle 5.7" rods, Dart 200cc Iron Eagle heads, auto w/ BTE 3000stall lockup, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" headers, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback.
1987 Camaro Z28 - 5.2tpi, auto, 3.73s, ram air, airfoil, ported plenum, !cat, !tbcoolant, !smog, !4th gear - FOR SALE
Old Nov 2, 2001 | 11:59 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Yes!
GTA -89:383, 4-bolt,Free flow muffler,dual 3" HF cats, Edelbrock headers, Canfield heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTR, !plenum, 52 TB, MSD 6AL, TPIS level V prom, Superior shift-kit and all the minor mods,looking for a SR ...
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Old Nov 3, 2001 | 08:16 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
Sure, count me in.
Old Nov 3, 2001 | 12:39 PM
irocz's Avatar
Car: '87 IROC-Z
ok I will set the page up at www.danieldale.com/dfi.html everyone email me your files and your mods and any comments you want to add & I'll post them there.
Dan
[This message has been edited by irocz (edited November 03, 2001).]
I fixed the link -RCR
[This message has been edited by RCR (edited November 06, 2001).]
Old Nov 5, 2001 | 07:25 AM
RCR's Avatar
RCR
Just curious when you will have something up. I sent you my files, and updated my site with them.
Old Nov 5, 2001 | 09:03 PM
irocz's Avatar
Car: '87 IROC-Z
they're there now, don't let the period get stuck on the end of the link above or here it is again http://www.danieldale.com/dfi.html
Old Nov 6, 2001 | 06:58 AM
RCR's Avatar
RCR
Good deal Dan.
So, can anyone answer "Where is my torque?" It just seems low compared to others with similar set-ups.
Old Nov 7, 2001 | 10:20 AM
nice3rdgenz's Avatar
i like the web page
Old Nov 7, 2001 | 10:26 AM
iroc90's Avatar
that site sounds like a good idea i have a 90 dfi iroc that needs help i will email u the program so u can post it
Old Nov 8, 2001 | 06:26 AM
Norm Peterson's Avatar
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
Thanks, Dan. Just added it to "Favorites". Something like this is probably overdue.
RCR - are you running a knock sensor? And what CR? First glance at the swap page pix and the lower left quadrant of your ignition values looks a little lazy compared to mine (>50% load and <3200 rpm). For reference, I'm running a 355 with the SuperRam and 62cc AFR 190's (around 10.2 CR) and LPE's 213/219 cam. I'm sure that my ignition map never goes into single digits, and I'm not getting any retard either.
Norm
1979 Malibu w/some cornering tweaks and a few other interesting things
Old Nov 8, 2001 | 07:10 AM
RCR's Avatar
RCR
Norm,
Yes I'm using a new 350 knock sensor. I had the same problem with the original 305 sensor. The CR is about 9.2:1. From a dead stop, I can nail it and not have any retard, but from a 20-30mph roll, I get A LOT. That's why I backed the timing down. It still retards, but not as bad. It seems to be a problem that I've always had, and can't get rid of. Last time I dyno'd the timing was more aggressive.
Old Nov 8, 2001 | 07:13 AM
RCR's Avatar
RCR
Geez Dan, where do you put all those cars?
Old Nov 8, 2001 | 12:39 PM
Car: '08 Mustang GT
Engine: 4.6L
<font face="Verdana, Arial" size="2">Originally posted by RCR:
Norm,
</font>
From a stop, what does the engine rev to and are you feathering the gas to keep out of wheelspin?
From the roll, is it downshifting all the way back to low gear or does it only drop back to 2nd? Does it retard as badly from, say, 45 - 50 roll?
Unfortunately Calmap's data recording won't directly track tranny gear, and the torque converter makes it more difficult to pick up the gear downshifted to from the rpm history, but you could try recording some runs in snapshot mode with rpm's and timing, MAP, %throttle, etc. I think that the sample rate is better with fewer things selected.
Perhaps some more info about fuel pressure & injector size would help track down anything to be found in the fuel map. I've only worked with my own system, which I'm sure differs from yours in these parameters, but maybe somebody else will jump in. Anyway, the only thing I saw there that I didn't expect (and it's probably minor) is in the row that starts on the left with 44 - about halfway up the rpm's it drops a couple of counts, then rises by over 20% (68, 70, 72, 70, 86, 90, 98). Does 2600 - 3000 rpm suggest anything? Neither the row above nor the one below does anything anywhere near that drastic, although there are also some big jumps at higher rpm's under lighter load (65 to 83, 57 to 81, 62 to 75, 50 to 65, and 45 to 58). I wonder if that causes any difficulty in the interpolation (that possibility was suggested to me by one of Accel's EMIC people when I was first getting mine set up, although not in so many words).
Hope this helps.
Norm
Old Nov 8, 2001 | 02:32 PM
RCR's Avatar
RCR
A little more info (Thanx for the input Norm, BTW). 24lb LT1 injectors. I believe the pressure is around 48psi, but I would have to check to confirm.
The fuel curve gets a little jumpy in spots because the original table was way too rich after I put the LT4 Hot cam. I worked the numbers down so that everything looks good in everyday driving. The spots where it jumps are areas that I can't "safely" check in everyday driving situations.
The area that seems to give problems is the lower left and across the bottom two rows. That's where I'm at when the knocking occurs. Trying to pinpoint it, I'd say 1200RPM area from &lt;50% load moving quickly to 80%+ load. That's when the knock counts jump.
Old Nov 8, 2001 | 03:27 PM
Car: '08 Mustang GT
Engine: 4.6L
Any chance the cam is advanced a little too far and the intake is closing too early?
I'll try to get something out of my laptop that's more recent for some comparisons.
Norm
[This message has been edited by Norm Peterson (edited November 08, 2001).]
Old Nov 12, 2001 | 11:16 AM
DavidR's Avatar
<font face="Verdana, Arial" size="2">Originally posted by irocz:
</font>
I'd be very interested in this. I've been working on getting my DFI system installed and running for about 8 months around other projects. Finally getting down to the tuning part. Fuel leaks were a bugger.
David
'73 L-82 (ZZ-4) and '96 LT-4 vettes
Austin, Texas
Old Nov 12, 2001 | 02:01 PM
irocz's Avatar
Car: '87 IROC-Z
Geez Dan, where do you put all those cars?</font>
I've got a big parking lot all to myself.
I'm going to try and get my DFI installed this weekend, but I still have some vacuum leaks to chase down first and I need to find a non-maf tpi intake boot.
Old Nov 26, 2001 | 06:29 PM
RCR's Avatar
RCR
Anybody else contributing????
Old Dec 19, 2001 | 07:15 AM
RCR's Avatar
RCR
back to top
ttt...
Norm, I fixed the knocking problem (knock on wood ..no pun intended). It would seem that I was running into a lean condition with large changes in MAP pressure. I just fattened up the transition table and voila, knocking gone.
Old Dec 20, 2001 | 05:36 AM
Car: '08 Mustang GT
Engine: 4.6L
Eventually. Diskette drive in the laptop died.
Norm
Old Dec 25, 2001 | 09:26 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: DFI programming information swap page
The problem is folks will assume they are onto something good and tend to repeat others mistakes.
Your better to rough it out and actually learn what works for your car then coping others.
People so often go to the more timing the better mindset, and just compund their errors from there.
Sad but true
Old Jan 11, 2002 | 09:12 PM
irocz's Avatar
Car: '87 IROC-Z
damn guys I'm pretty disappointed in the response. I know more of you are out there. does anybody give a damn???
AussiePr0nCar
Mar 6, 2020 04:04 PM
midge54
Dec 27, 2019 04:14 PM
gta90
Sep 15, 2015 04:00 PM
bdads
Aug 24, 2015 06:01 PM
marcusaw
Aug 10, 2015 08:13 AM
