Getting ripped off?
Old Jan 28, 2016 | 10:50 AM
Ajdd94's Avatar
Car: 1992 Camaro RS
Engine: L03 TBI
Getting ripped off?
Hi Im new here i have a 92 305 tbi with vats completely shutting the fuel and crank off.. a local guy is charging $200 for a vats chip with stock tune. Should i go that route or buy my own chip burning equipment and do it myself? Thanks
Old Jan 28, 2016 | 11:00 AM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Re: Getting ripped off?
Yes that's quite a ripoff.
Old Jan 28, 2016 | 11:07 AM
Ajdd94's Avatar
Car: 1992 Camaro RS
Engine: L03 TBI
yeah i figured. now i dont know what to buy or where to look to buy it, if anyone would guide me to the right direction it would be greatly appreciated
Old Jan 28, 2016 | 11:11 AM
Engine: LB9
Axle/Gears: 3.08
You need an ALDL cable, tunerpro, a prom reader/burner, a spare EPROM ideally, and an adapter for a memcal probably.
The stickies up top in the two tuning forums are pretty helpful but can be confusing for noobs.
You could also put a resister in the VATS wire and bypass all that. I know fourth gens can do that I assume it's very similar in third gens.
Google: vats bypass site:thirdgen.org
Old Feb 2, 2016 | 01:26 AM
xwarp's Avatar
Car: '85 S15
Engine: '93 3.4 60v6
For $75, I'll burn you a factory chip with the vats turned off. I'll even supply the chip if it's a 2732 and ship it priority.
Jeeze...
What some people charge for stuff like that.
Old Feb 2, 2016 | 08:08 AM
OrangeBird's Avatar
Car: 1989 Firebird
To eliminate VATS , there are a couple of different ways . Yes , you could have a chip burned with no VATS , or you could try the 75 cent resistor bypass providing the VATS module itself is still functional , or if the VATS unit itself is totally dead there is a small cheap aftermarket circuit board that can trick the ECM into thinking VATS is present and working . I think I've seen the aftermarket VATS elimination module for around 40 or so dollars . This of course requires wiring know how to install , so if you have no wiring know how then by far Xwarp's 75 dollar chip sounds like the best option for you . It's all depending on how far your willing to go , wiring wise , as to what the final pricetag will be .
Old Feb 2, 2016 | 09:01 AM
xwarp's Avatar
Car: '85 S15
Hell, I'll do it for less than that. I don't know why I stated that much, but hey, if you were willing to pay that much, then 75 would be a better price.
In any case, send me a pm, I'm up for bartering and can burn chips as I have an eeprom programmer.
Old Feb 2, 2016 | 11:10 AM
Ajdd94's Avatar
Car: 1992 Camaro RS
Engine: L03 TBI
Jeeze...
do you happen to be located near los angeles.. no offense i just like more face to face transactions
Old Feb 2, 2016 | 03:04 PM
xwarp's Avatar
Car: '85 S15
I live in Tucson Az.
Send me a pm if you want, we can work something out if you are interested.
jonarotz
May 25, 2017 11:07 AM
rusty vango
Jul 5, 2016 03:09 PM
ev305tpi
Feb 6, 2016 09:40 PM
Alex Fields
Jan 28, 2016 04:19 PM
Alexc299
Jan 28, 2016 09:35 AM
