How To Identify Performance Chips?
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
I recently went to re-run a new power wire for an AMP and under the passenger dash section I found a little silver box w/ Electrical Tape -_- on both ends...as if that's what's keeping it together, lid on, etc. I'm assuming based on what I've read this may be the ECM. How do I know if a "performance chip" was installed by a P/O. What's the best way to inspect/identify? Any precautions I should take?BTW, I searched for related threads and in the sticky's....zilch!
Thank you,
Car: 89 Firebird
Engine: 355 TBI
Re: How To Identify Performance Chips?
https://www.thirdgen.org/forums/atta...1&d=1465931746 Don't know if this helps but here is a pic of my "factory chip" when I removed it". If yours is factory the #s should match.
Engine: 305 / 350
I will disco the battery, un-tape, and inspect. This will have to be tomorrow morning, I'll take pics and update accordingly.
I hope I do not foul anything up,
I've not read about anyone else having a freggin taped up ECM...
Thanks for the Image dmccain.
I've not read about anyone else having a freggin taped up ECM...Thanks for the Image dmccain.
SexyCamaro
Car Audio
Aug 5, 2001 01:50 AM
