What ecu is this?
Old Jul 25, 2017 | 06:35 AM
HellHound's Avatar
Car: I drive trans am. Duh
Engine: Yes, I have one in the trans am
Transmission: I have one of those too In trans am
Axle/Gears: In the rear of trans am
What ecu is this?
Found a junked vette at the yard with what I think is a remain ecu. The cover was sand blasted. I don't know what I am looking at for internals wise to tell me what it is. I have not picked it up yet but I want to make sure it would work for my tuning needs. I did get the plugs and prom. Thanks for any help.
Old Jul 25, 2017 | 08:24 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: What ecu is this?
Looks to be the 1227165 MAF TPI ECM. Even as a re-man there should be a part number on the top of the case.
RBob.
Old Jul 25, 2017 | 08:12 PM
HellHound's Avatar
It is an 8259 ecu. Is that any good?
Old Jul 25, 2017 | 08:25 PM
HellHound's Avatar
Is there anything else I need to go back for to pull out of the vette for this conversion?
Old Jul 25, 2017 | 08:27 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Superseded 165
Old Jul 25, 2017 | 08:28 PM
Engine: Lb9
Transmission: M20
What conversion are you doing ?
Old Jul 25, 2017 | 09:41 PM
HellHound's Avatar
Drop in the new ecu in place of the one I have in my 85 T/A
Old Jul 25, 2017 | 10:09 PM
GeneralDisorder's Avatar
It is not directly compatible with 85. No other year is compatible with 85. If you change to an 86+ MAF (and it may need other changes also - I'm not sure) it could be made to work.
GD
Old Jul 26, 2017 | 05:59 PM
Engine: Lb9
Transmission: M20
https://www.eecis.udel.edu/~davis/z28/ECMs/85to86.txt
