Ecm conversion help
Old Jul 27, 2017 | 09:00 PM
jdawg77's Avatar
Car: 1989 convertible
Engine: 383
Ecm conversion help
Hello, I aquired a mostly finished 89 convertible. It has a new 383 with the tpi from a 1992 iroc. I am trying to finish up and will be needing a tune. I took the ecm out to see what i have and am confused by what i see. Excuse my ignorance but im new to tpi swaps. please see pics . Thanks in advance.
Im not sure what this writing means.
Old Jul 27, 2017 | 09:17 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Ecm conversion help
Nvsram
https://www.thirdgen.org/forums/diy-...ion-board.html
Old Jul 27, 2017 | 09:31 PM
Engine: Lb9
Transmission: M20
Axxb is a 305 automatic tune.
Old Jul 27, 2017 | 09:37 PM
jdawg77's Avatar
Engine: 383
Thank you! I still feel like an idiot because this is way over my head. Lol Is this just expanded memory? Do i still get the chip tuned like normal? Why does it look like im missing a chip on top? Again...sorry for being that guy :/
Old Jul 27, 2017 | 09:41 PM
Engine: Lb9
Transmission: M20
The memcal is missing the prom. The new tune is on the expansion board. This ecm was used in tpi 90-92 speed density.
Old Jul 27, 2017 | 09:44 PM
jdawg77's Avatar
Engine: 383
Thank you for your help! So the chip that is on the expansion board is the prom? Is that what used to be in the empty socket? If thats not the case how do i get a tune and on what?
Old Jul 27, 2017 | 09:54 PM
Engine: Lb9
Transmission: M20
The sockets not stock but yeh there use to be a prom there now there's a eeprom on the expansion board. The best way to get a tune might be to use a g1 from moates.net and remove the nvsram or look into the older tunerpro rt I think it was supported with that program.
Old Jul 27, 2017 | 10:03 PM
jdawg77's Avatar
Engine: 383
Thanks again. It looks like ill be continuing my research. Im still not exactly sure about this mess. Is this completely different than a normal chip? Can a place like sinister tune these as well? Am i better off ripping this out and getting a prom or new ecu? This is just not an issue i expected to run into.
Old Jul 28, 2017 | 03:51 PM
Engine: Lb9
Transmission: M20
If your going with a piggyback chip you can remove the nvsram and use the memcal and a piggyback board.
Old Jul 28, 2017 | 08:10 PM
jdawg77's Avatar
Engine: 383
I was told by sinister that my cam is to big to tune for. Im in the process of removing the harness and tpi setup to sell. Im going carberated. For me it will just be easier.
Old Jul 29, 2017 | 04:31 PM
Engine: Lb9
Transmission: M20
Just curious the cam specs
Old Jul 29, 2017 | 05:21 PM
jdawg77's Avatar
Engine: 383
294/300. Lift .540/.562
