383 swap
Car: 1992 Firebird
Engine: 3.1 6 cylinder
Transmission: 700R4 automatic 4 speed
383 swap
Hey everyone! So im getting rid of my 305 in my 90 firebird and swapping to a 383. So im curious about the wiring with that. Does anything need to be plugged into the bulkhead junction box at the firewall on the drivers side in place of where the engine wiring harness plugged in. Just wondering how everything else gets power. Thanks!
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: 383 swap
Way more info is needed. What fuel delivery method did the previous engine use? What fuel delivery method does the new engine use? Are you removing or adding anything?
Car: 1992 Firebird
Re: 383 swap
It was fuel injected. It has the electric in tank fuel pump. I am switching to carborator. And basically planning to buy msd 6AL ignition system
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 383 swap
Your thread is in the wrong section. Plenty of information on the carb swap just use the search.
Engine: Lb9
Transmission: M20
Re: 383 swap
Look at some of these current threads from a member that just did the swap.
https://www.thirdgen.org/forums/sear...archid=9510909
Car: 1991 Z28 Vert
Re: 383 swap
Stuff like that is covered extensively, from every angle in prior threads. You really need to do a simple search. You'll also have much better help if you post this in the carburetor message board. As a next step, review the electrical diagrams at www.austinthirdgen.org
This is the connector on the driver's side of the firewall: http://www.austinthirdgen.org/mkport..._1990_C100.gif
This is the connector from the interior wiring harness to the vehicle's ecm that supplied power and a few other wires depending on options: http://www.austinthirdgen.org/mkport..._1989_C207.gif
And I am going to assume you had a 305 TBI car: http://austinthirdgen.org/mkportal/m...ine_wiring.gif
Steven6282
Mar 21, 2011 06:26 PM
