MAP sensor install on SuperRam
Hey Gang,
Plan on installing the EBL ecm and trying to get a full handle on this.
I see the hole for the vacuum fitting for the MAP. Anyone know which fitting is needed? Plan on adding a blower in the future. Can I use a Map2 on an NA engine for now? It's an LPE 383 with Trickflow ported heads and superram.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: MAP sensor install on SuperRam
Any one of the ports on the map mounting surface will work. They are all manifold vacuum.
The nipples for hvac and map can reused from tpi.
Engine: Lb9
Transmission: M20
I don’t know the size of hole the newer style map uses. I think the map uses the same 5v signal.
Car: check
Engine: check
Transmission: check
I tried using one in a first startup but had some other issues and needed to put in known sensors. Ended up never going back as the pigtail was changed- very nice size tho.
WorkInProgress
Aug 28, 2014 12:23 PM
