Ecm 730 doesn't store check engine light codes
Old Jan 1, 2019 | 03:09 AM
moneyman380's Avatar
Car: 1991 Z28
I have a 91z28 355 built engine running a superram and an ostrich emulator with tunerpro software. Problem is when I first start it runs fine then within 15 minutes the check engine light kicks on. So i turn the car off and try to pull codes but get nothing.
Is there a way to pull codes while still datalogging with tunerpro ? Or is there a battery in the ecm which might be dead not able to store them ?
Old Jan 1, 2019 | 11:08 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Ecm 730 doesn't store check engine light codes
No battery in the ECM. It can take up to 20 seconds for a code to be stored. So if you are shutting the engine off too soon, let it run for a while.
Should get at least code 12. That shows that the ALDL port and ECM should be OK.
The malfunction codes are in the ALDL stream. Just need to pull them out via TunerPro.
RBob.
Old Jan 1, 2019 | 04:00 PM
Car: 1991 Z28
Yeah I get a code 12. I'll try to let it run longer
camaro87-alex
May 25, 2022 01:12 PM
joef2002
Aug 4, 2012 01:38 PM
Stevolwevol
Aug 12, 2010 09:23 PM
BlackZee
Jun 13, 2001 06:17 PM
