Brake warning light, linked to ECM?
Car: 85 firebird
Deleted the ECM on an 85 firebird, I was expecting a permanent CEL after the delete but I'm also getting a "brake" warning light. Is this also tied to the ECM? I don't rember unplugging anything tied to the brake system is what has me confused.
Car: check
Engine: check
Transmission: check
Re: Brake warning light, linked to ECM?
I'm not sure, but what about the switch on the brake distribution block? Is the wire still connected?
Car: 85 firebird
Yes the wire is still going to the block below the master cylinder, I didn't touch anything wiring wise except the ECM harness. I worked the park brake lever about 50 times and it went away, but now the light doesn't come on when I set the park brake. Think the switch is dead or the wire is faulty. Going to get a new switch and pull the center console.
