Determining ECU number
Car: 1985 Z28 Camaro IROC-Z
Engine: 5.0 305 TPI
Hi Guys,
Im from South Africa and have come across a 1985 Z28 Camaro IROC-Z with only 4014 original owner miles on the clock. the car has been sitting for quite some time. i have noticed that the ECU is missing apart from a windscreen, new lock set i need the original ECU. how do i go about sourcing the correct one for this car?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Determining ECU number
If your tpi it’s a 1226870. You can find on eBay.
Engine: 5.0 305 TPI
Engine: Lb9
Transmission: M20
You can look at the prom to see if it’s for a 305 automatic
. You might want to ask this seller for the letters off the prom.
https://www.ebay.com/itm/85-firebird-Car-Computer-Serv-No-1226870/133252267239?hash=item1f06743ce7:g:dQUAAOSwqwRd0-pP
Any of the 305 Automatic codes will work
https://chevythunder.com/prom_bcc_1985.htm
Engine: 5.0 305 TPI
Thank,
So its literally just hope that the prom code matches anyone of those codes for a 305 Automatic and it will run?
Engine: Lb9
Transmission: M20
There is another thing you might need. That is the maf relays. They are in a separate box that piggybacks on the ecm.
https://www.ebay.com/itm/Corvette-Bu...kAAOSwjBVbx81x
Engine: Lb9
Transmission: M20
Engine: 5.0 305 TPI
collecting the car on saturday so i will then see what else is missing and let you know. Can i not go through you for an ECU and whatever else is needed?
Engine: Lb9
Transmission: M20
Unfortunately I do t have the ecm or burn off module.
you should signup for eBay or post in the classifieds wanted section on this site.
