355 tpi / turbo / 4l80 HELP!!!
Old May 27, 2020 | 07:50 PM
confucius101's Avatar
Hey guys i am at a loss here
time to get my 92 formula finished
I'm getting ready to drop in a built 355 tpi turbo with a 4l80
I'm trying to find a setup that can control and run everything
I called Holley and once they heard 92 they went straight for their stealth setup and started adding part numbers and $$$$$$$$$
and they would not even talk to me about any other options LOL
will a deliminator or terminator kit work for my setup???
please any and all input and recommendations brands options needed
Old May 27, 2020 | 10:02 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 355 tpi / turbo / 4l80 HELP!!!
Terminator x max with 24x crank harness may work
you’ll need to mount a crank trigger, like holleys 36-1 hall effect kit.
OR efi connection 24x reluctor ring kit with timing cover. The plastic late model vortec cover might work on your block since its a late model
get efi connections 1x cam sync distributor.
get some ls1 coils or other ls coil pack for boost like the D581’s.
you will need to extend the holley lsx harness to reach those cam and crank sensors and likely some other sensors like tps iac coolant etc. may even need to add the right tpi pigtails but it will work
i have run the ls1 harness and oem pcm on my turbo sbc and now using ls1 holley harness on my turbo big block just modded for pigtails and length. Using holley 36-1 trigger and efi connection 1x dizzy.
Old May 28, 2020 | 01:46 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
This is where it gets expensive, but it doesn't have to be that expensive. I am in the same boat by upgrading to an electronic transmission, but the current ECU I am using has no control over it. But rather than swap ECU's at this point and go with say a Haltech, I went with a standalone TCM. Depending on manufacturer, will run you between five to seven hundred. I would recommend this if you already have an ECU to control your boosted engine and just need trans control...
- Rob
Old May 28, 2020 | 09:45 AM
Thanks for the response guys.....
Old May 28, 2020 | 04:35 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
saw this https://sites.google.com/site/sloppy...ans-controller
and this http://mattw.dyndns.org/4L80E/
cheap ways to run the 4l80e
Old May 30, 2020 | 11:24 PM
thanks for all the feedback I ended up going with a BS3 kit
ill keep you posted as things progress
Old May 31, 2020 | 09:14 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Wow bigstuff? That always seemed to be more drag race oriented. Seems like an odd choice considering other options. I guess they must have upgraded some of their stuff?
Old Jun 1, 2020 | 06:57 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
I have to agree with Orr on the BS3. Didn't think anyone even ran it anymore. I was always under the impression it didn't work well on the street.
SketchyZed
Alternative Port EFI Intakes
Dec 16, 2021 02:16 PM
confucius101
Jun 7, 2020 12:46 PM
L98IROCZ89
Aug 13, 2002 11:57 PM
Bad406Z
Jan 26, 2002 02:17 AM
