Question hsri to tpi tune
Old Jun 2, 2020 | 07:33 PM
bensbaby's Avatar
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
I have a 88 gta trans am Pontiac firebird tpi 305 tpi t5
and 2 years ago I made a 383 sbc I had a custom chip burnt I have a hsri and bbk 58 tb
I miss my low end tire burn out tq
I have a t56 now
and I want to know going from my car tune to a tpi can I use the tune I have now
or does it have to be returned for the tpi
ty
Old Jun 2, 2020 | 10:38 PM
ULTM8Z's Avatar
Re: Question hsri to tpi tune
I have a t56 now
ty
Not trying to be a jerk, but please try to write in complete sentences. It's hard to understand what you're asking.
Are you saying you want to run a TPI tune on a HSR 383?
BTW, if you don't have tire shredding torque with a HSR 383 and anything close to a streetable camshaft, there's something wrong with your current tune. I'd focus on getting that right.
Old Jun 3, 2020 | 02:53 PM
bensbaby's Avatar
Engine: 383 built
I was asking I have a hrsi now I want to go back to tpi
will my tune from my hsri work with my tpi
Old Jun 3, 2020 | 02:56 PM
bensbaby's Avatar
Engine: 383 built
I have a lt1 hot cam
roller
it's goes to 5500 to 6000
and I can't even drive the car on the street as it is
it is getting a ls1 front brake upgrade in 1 week and then I will be better
it pulls like a raped bitch
I just don't drive it that way.
it's good for drag racing track and that's it
I street my car 99% of the time
Old Jun 3, 2020 | 04:23 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
The torque boost in the2800-3400 range likely will want more fuel than the hsr tune. Maybe even a deg or two less timing depending how aggressive your tune is now. The hp peak rpm comes down with tpi and so will the peak number so it may want less fuel in the 4000-5000 range. Def less above that but you wont need to run over 5500.
iT wont be optimal But it will likely run
Old Jun 3, 2020 | 04:28 PM
bensbaby's Avatar
Engine: 383 built
Ok
that's what I thought
ty
now I have to decide wtf I'm gonna do
it used to be with a low compression motor I had a 305 tpi t5
and 9 bolt
I did 14.3 at 99 burning out 245 street tires non stop
I could floor the car anywhere down low and it would smoke posi 2nd gear and chip 3rd gear
275 hp and 375 tq engine at a dyno
I and if I floor it 2nf gear like I used to it doesn't do **** untill after 4500
and by that time in going so fast I can't stop
I need suspension and shocks
and the ls1 front brakes
Old Jun 3, 2020 | 05:50 PM
ULTM8Z's Avatar
My guess is the accelerator enrichment routine is way off on your HSR. Those short runner manifolds such as the HSR and Miniram like a very different AE profile than TPI's.
On my Miniram, I've found that proper AE "sets the tone" for how the engine follows through afterward on how it pulls. If it bogs on AE, you're done (either too much AE fuel or too little)... it just feels sluggish and doesn't recover for a while... But when it's right, you can really feel the difference... the transition from AE fueling to PE is seamless.
Frankly I can only imagine how much power and torque I'd have if I had a 383 under that Miniram.
Just be aware, when you put TPI on that 383, you're going to be extremely disappointed above ~4500 rpm... I agree with Orr that it'll probably "run", but you'll be shortchanging that 383.
Old Jun 3, 2020 | 06:15 PM
GeneralDisorder's Avatar
I would go with the FIRST TPI instead of the stock TPI. That will be large enough to run properly on the 383 and still give you the torque you desire.
And you need to do a proper dyno tune. E-tuning something like that is only good for startup and driving to the dyno.
GD
Old Jun 3, 2020 | 07:53 PM
bensbaby's Avatar
Engine: 383 built
Ty guys
I'm just gonna keep what I got for now
Terrence1725
Dec 18, 2013 06:13 PM
darkhorse91
Aftermarket Product Review
Mar 27, 2010 02:26 AM
TXFBODYGUY
Sep 15, 2009 01:41 AM
firefrombelow
Jan 5, 2005 09:49 PM
