Knock sensor differences
Old Jun 27, 2020 | 07:05 PM
elesone's Avatar
I have to apologize up front. I have a heck of a time using the search utility. Every time I do search, I get a bunch of choices that don't even come close to what I need. Maybe I'm not doing this right. But anyways here's my question. Why are the knock sensors different between the Z28 and RS. Ran across this on ROCKAUTO.com. Almost ordered the wrong part number, so I'm holding of for a reasonable explanation. Thanks.
Old Jun 27, 2020 | 07:26 PM
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
Re: Knock sensor differences
What year?
RS is V6 I believe
Z28 is V8 which could be 305 or 350
So 3 different knock sensors
I'm answering without looking up so I could be in the left field
Cheers
Old Jun 27, 2020 | 07:30 PM
GeneralDisorder's Avatar
Different engine's use different sensors. They are tuned to listen at different frequencies. That frequency is chosen based on the bore size typically.
GD
Old Jun 27, 2020 | 08:07 PM
elesone's Avatar
SbFormula - 91 Z28 305
GD - Sounds logical.
Is there a way to check them if there's no markings legible?
Old Jun 27, 2020 | 08:11 PM
SbFormula's Avatar
Engine: LT1 6.2L
Axle/Gears: 3.91
For 305
gm # 10456126 for TPI
gm # 10456287 for TBI
enjoy
Old Jun 27, 2020 | 08:20 PM
Unfortunately there is no way I'm aware of without sophisticated testing equipment capable of generating specific frequencies and investigating the waveform produced by the sensor.
GD
Old Jun 27, 2020 | 08:22 PM
elesone's Avatar
Awesome. I checked the one I have and the resistance between center probe and body measures 8190 ohms. Don't know if it's the right one, TPI or TBI. No markings on it.
Old Jun 27, 2020 | 08:30 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/tpi/...k-sensors.html
Old Jun 27, 2020 | 08:41 PM
elesone's Avatar
Thank you TP.
Old Jun 27, 2020 | 09:58 PM
Ohm test doesn't tell you which frequency the sensor responds to. Only which type of computer it was designed for. They made both types in at least 3 frequencies.
GD
Dissolve
Oct 26, 2003 01:15 AM
TunedPortZ
Jun 6, 2002 07:14 AM
formula14
May 31, 2001 01:03 AM
