Engine light is solid won’t give me any codes
Old Jul 21, 2020 | 07:30 PM
Boodog9's Avatar
I’m new on here . Anyway I have an 82 Z28 CFI with 29000 original miles everything is original except the tires and ECM. I bought a new ECM because I had a very high idle advised by a mechanic. Still have the high idle and now a solid engine light that won’t give me any codes.
Old Jul 22, 2020 | 08:31 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Engine light is solid won’t give me any codes
Sounds like the ECM is dead. If the older CFI ECMs are like the slightly newer ECMs (TPI & TBI), it should blink the SES/CEL light at key-on, engine-off. This is a decent test to see if the ECM is actually running from the firmware and not in limp mode. Test is as follows:
While observing the SES/CEL light do a key-on, engine-off. The SES/CEL light should briefly turn on, blink off, then turn on solid. Can repeat the test after at least 10 seconds of key-off. The blink-off is the key, with that the ECM is running from the firmware.
RBob.
JAYCREDIT
Mar 14, 2012 11:02 PM
lopezstud87
Dec 5, 2011 05:02 PM
90_T/AGTA
Nov 11, 2010 11:09 AM
irocz813
Feb 27, 2010 09:13 PM
fbird92
Apr 10, 2006 08:12 PM
