Getting Back Into EFI
Old Sep 29, 2020 | 12:05 PM
88TTFB's Avatar
Car: 88 TA
Engine: 5.7 TPI
I have been out of the loop for years and the car had been garaged since 2012. I had the engine built and I want to get back into this beast. The plan is Twin Turbo L98 24PSI. I have the turbos and the engine was built around a 24lb boost target. Fully forged, inconel valves, ect, ect. Where I stopped was intake, fueling and ECM. The plan back then was Stealth Ram, Mototron 60lb injectors with a 7730 and Code 59. Code 59 seems to have faded so with all the new technology I am hoping to lean on some experience and trusted installs. EBL P4 looks interesting and I like that it is member created. I would appreciate some input as to what everyone is running these days or if the original plan with Code 59 is still valid. I still have all the Moates stuff that I purchased for it and still can go that route if practical. I would have to think that over the years the technology has greatly improved though.
Thank You
Old Sep 29, 2020 | 12:41 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Getting Back Into EFI
$59 works well. I always liked it if you have the files. It always ran good on my engines
theres a $8D-T code here now thats boosted $8d but i think its only 2 bar. Might beable to rescale it to 2.5 or 3 bar.
24 psi is an odd target. Usually just go by power goal and estimate what it will take to get there.
i used ebl on one car and it was good too. Liked how it worked.
if you can afford it go holley HP lol
ZZ3Astro
Sep 8, 2014 12:07 PM
GTA
138
Aug 22, 2012 05:04 PM
88 350 tpi formula
May 3, 2008 09:19 PM
moneyman380
Sep 6, 2005 05:50 PM
JohnL
Jan 20, 2003 01:57 AM
