ECM REPLACEMENT
Old Feb 7, 2021 | 09:26 PM
Cougar242's Avatar
Car: 1989 iroc
Engine: 5.7 tpi vin 8
ECM REPLACEMENT
I pulled the ecm from my 1989 iroc with a tpi and vin 8. I found out it has a cardone ecu with a delco APYN 3496 chip. I am wanting to go back factory with the ecm and prom but I am having a hard time finding either online. Does anyone know what part number I should be looking for or who would have these in stock.
Old Feb 7, 2021 | 09:28 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ECM REPLACEMENT
1227165 is the factory service number. That is the correct memcal for your car.
Old Feb 7, 2021 | 09:31 PM
Cougar242's Avatar
Car: 1989 iroc
Re: ECM REPLACEMENT
Thanks for info I found that number by reading threads and I have searched all day including the delco and gm parts website they either say not found or I can not find the ecm available anywhere. Do you have any suggestions or know who might carry the ecm?
Old Feb 7, 2021 | 09:57 PM
Engine: Lb9
Transmission: M20
Re: ECM REPLACEMENT
If your wanting one with a sticker different than your remanufactured one look on eBay or post in the classifieds wanted section.
Old Feb 8, 2021 | 11:17 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ECM REPLACEMENT
A newer number for the '7165 ECM: 16198259
Note that the cardone ECM is an OEM GM ECM.
RBob.
Old Feb 8, 2021 | 11:52 AM
Cougar242's Avatar
Car: 1989 iroc
Re: ECM REPLACEMENT
Ok thanks for the info everyone been trying to read the threads and seen alot that said cardone bad get an oem one so basically the one I have is OK
thanks
Old Feb 20, 2021 | 03:56 PM
larry88ttops's Avatar
Car: 1988 Camaro w/T Tops
Engine: 305 TBI
Transmission: Borg-Warner 5 spd
Re: ECM REPLACEMENT
I just now saw this string and wanted to add my two cents. I was able to get an ACDelco GM remanufactured ECM from my Chevy parts dealer just last month, so I know that they're out there! Good luck!
zz's z28
Mar 17, 2016 11:30 PM
DiabloWS6
Mar 15, 2011 08:46 PM
BlackMamba
Jul 14, 2009 09:37 PM
85_TA_WS6
Apr 4, 2007 10:45 AM
DA 89 CAMARO
Sep 20, 2004 12:42 PM
