Need help!! Ecm on fire
Old May 23, 2021 | 06:43 PM
Makeitreal81's Avatar
So I have a 1226870 ecm and it was running like crud figured it was the injectors (it's been sitting for around 20 years and fuel pump went out). Anyway took it for a hour test drive before driving 5 hours home and the ecm burnt up. Opened it up and the middle and left quad drivers (I think could be wrong) are burnt to a crisp. Does anyone know what these correlate to and do I need to worry about wiring?
P.S. spent the weekend undoing hackoiry from both my father trying to remove the old school security and the security itself.
Old May 23, 2021 | 06:44 PM
Old May 24, 2021 | 08:20 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: Need help!! Ecm on fire
Id unplug the ecm and everything I didn't need and throw a carb on it
Old May 24, 2021 | 08:47 AM
That's not very helpful my friend😂
Old May 24, 2021 | 08:50 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Pretty sure this is the link to schematic
https://pcmhacking.net/ludis/1227170sheet6.gif
Old May 24, 2021 | 08:51 AM
Engine: Lb9
Transmission: M20
Cheap just change the prom and calpak
https://www.ebay.com/itm/31300438234...EAAOSwH1NeTu0I
Old May 24, 2021 | 08:52 AM
Engine: Lb9
Transmission: M20
Or better yet do the 870 to 165 conversion
Old May 24, 2021 | 09:02 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
May be. When it burns to the ground you may have wished you would have done away with all that rotten wiring. If it was a running car and this was a new issue Id be thinking differently but 20 yrs of mice chewing wires Id be getting it down to bare minimum wiring. Probably atleast look into a new harness altogether.
Old May 24, 2021 | 10:26 AM
Engine: Lb9
Transmission: M20
Sounds like just internal ecm issues not a harness issue
Old May 24, 2021 | 10:48 AM
No evidence of mice present unless you consider my dad and the alarm installers mice😂😂 Its funny cause my dad was 6'2". Now the vehicle has spent most of its time sitting in a nice garage so the majority of everything is good and intact. The fuel pump/tank rotted from the inside out gotta love ethanol.
Old May 24, 2021 | 10:51 AM
I would but cars 5 hours from home and I just ordered a new ecm. I found someone else and it was suggested that it may be a bad solenoid so I'm going to ohm out all the solenoids and hope that it's one I can temp run without like evap or egr
Old May 24, 2021 | 02:46 PM
Forgot to say thank you all!! I'll post what I find this weekend if I'm not too busy getting her up and running.
Old May 25, 2021 | 07:11 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
You need to check every actuator that the ECM controls. Such as the TCC solenoid, fan relay, EGR solenoid, CCP solenoid and so on. Otherwise the next ECM will look the same.
Get the wiring diagram for the EFI/ECM, unplug the ECM, and measure the resistance of the actuators from the ECM harness end. Any that are lower then 22 ohms are bad. It may even be that some wiring is shorted hot to the q-driver.
RBob.
Old May 25, 2021 | 08:44 AM
RBob.
Thank you so much. This is what I was looking for, but I had found it by doing a more generalized search yesterday. So that's the plan and fingers crossed whatever it is it'll be able to live without so I can get it home. Tempted to tear apart my trans at home and pull the solenoids out of it so I have them ordered new injectors already and I can open the circuit for the fan if its needed.
Old Jun 1, 2021 | 08:45 AM
So update I got it home!!! Although it did destroy the new ecm. Stupid egr solenoid almost caught on 🔥. So my question at this point is do I replace current ecm or do I upgrade or go to megasquirt? Is there anyway way to protect the ecm when a solenoid goes bad? I work on high end cars and it seems rediculious to me that a solenoid WILL take out an ecm. If I have to fuse every line or install bypass resistors I will.
Old Jun 1, 2021 | 09:12 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Replace the three quad-drivers with newer ones. They are over-current protected. GM did this same thing after finding what you found. Recall that '85 was the first year for this style ECM.
The TI/Nat-Semi DS3668 is still available and is a direct pin compatible device.
If the PCB board is still OK you may be able to repair the two ECMs you have. Every now and then the bad q-driver will take out the chip that turns it on & off.
RBob.
Old Jun 1, 2021 | 11:15 AM
RBob.
Thank you. That's so helpful. I'm not great with repairing microchips, but I can upgrade the ecu to a newer one and not be worried about it as much. I was wondering why I didn't have these issues with my old '87 and '89 tpi camaros I had when I was younger. They had other issue like rust, but the ecus worked good😁
ozmike00
Nov 12, 2014 03:22 PM
trueburton
Sep 15, 2009 05:30 PM
Rebuildman
Jun 24, 2008 08:23 AM
Gta-Paladin
Mar 4, 2002 09:02 PM
