IAC Bench Test
Old Feb 25, 2023 | 10:48 AM
Marineengineer5's Avatar
Car: 2006 Ford F-250 Diesel
IAC Bench Test
Fighting a High Idle Issue, idles @ 1200 RPM. So I smoke tested intake thru a Vacuum Port, no indications of leak. Performed the IAC Reset procedure, now idles @ 1500 RPM. Reset TPS to 0.55vdc, no change. Bad IAC???
Pulled the IAC out and set up on bench with a 5vdc pulse, IAC Jerked once, then nothing. Tried shifting polarity, no motion, tried both motor winding, no motion. Each motor winding reads 58 ohms. IAC is open @ 29mm (spec is 28mm)
Not a big fan of the Parts Shotgun Effect. Too much time at sea without a parts counter to buy parts.
Before I pull the trigger on a new IAC, any ideas?
Old Feb 25, 2023 | 02:02 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: IAC Bench Test
The IAC is a bi-polar stepper motor. It runs from 12 volts. There are some hobbyist circuits out there to run one. Note that bi-polar means that there are two coils. Of which the polarity goes forward and reversed, dependent upon whether to step in or step out. Along with at which point the stepping is.
Do need electronics to run an IAC. Way back I built a box to do this. It does come in handy. But for the most part is hardly used.
The first part of the IAC set up (minimum idle air) procedure continuously steps the IAC closed. Don't do this with the IAC out of the TB.
RBob.
Last edited by RBob; Feb 25, 2023 at 05:21 PM. Reason: speelling, or some such thing...
Old Feb 25, 2023 | 04:04 PM
Re: IAC Bench Test
Hmm, 12 volts you say? That could explain the no movement. I will try to pulse 12vdc on the coils. If there is movement, I will report back. I am used to 5vdc on Servo Motors (time in the navy as an ET). Once I prove the IAC is good, I will pulse to achieve 28mm and reinstall. More in the AM. Thanks RBob. The service manual provides no info on this. MUST USE TECH 1 AND A GM TRAINED SERVICE TECH. ;-)
Old Feb 25, 2023 | 04:17 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: IAC Bench Test
No stop on the iac, watch the pintle doesn’t shoot out
Old Feb 26, 2023 | 09:58 AM
Re: IAC Bench Test
Update. Installed IAC back in the Throttle Body Lower Plate. Applied 12vdc, no motion. Tried various configurations for the 12vdc supply, nothing . Need a new IAC
While I was at it, pulled the MAP Sensor to verify operation using 5vdc. Pulled 20" of vacuum, voltage dropped from 4.8vdc to 0.950 vdc. Watched the voltage slowly rise over a 45 second period while holding 20 " of vacuum from 0.950 to 1.030vdc. Hmmmm, going to replace the MAP as well.
Nothing to complain about, had the car for 18 years with no issues. Time catches up to all of us.
Old Apr 8, 2023 | 07:24 AM
Rumblin70SS's Avatar
Car: 88 IROC-Z T-Top car with Bose
Engine: L98 5.7
Axle/Gears: 9 Bolt with 3.27's
Re: IAC Bench Test
Hello there,
Did you happen to fix this issue? Have a friend fighting a similar problem. All help is appreciated!
Old Apr 10, 2023 | 02:34 PM
Re: IAC Bench Test
Rumblin70SS,
No sir, still having issues getting the engine started. I am troubleshooting a bad ECM as I can't even get a NOID Light to indicate an injector pulse. New(refurbished) ECM due Wednsday(?). I will report back.
Old Apr 10, 2023 | 07:06 PM
Engine: L98 5.7
Re: IAC Bench Test
Ugh thank you, look forward to hearing back and good luck!
Rumblin70SS,
Old Apr 10, 2023 | 08:33 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: IAC Bench Test
High idle might be due to a bad temp sensor feeding the ECM? Do you have a scanner?
Bairdracing77
Aug 19, 2011 09:24 PM
NatesL98
Feb 2, 2008 11:51 AM
Z69
Dec 25, 2005 01:12 PM
JPrevost
25
Jul 30, 2002 12:01 PM
slowTA
Jul 2, 2002 10:20 PM
