Knock Sensor codes on '91 Suburban
Old Mar 12, 2023 | 07:04 AM
JuanAntonio's Avatar
Car: 91 Suburban
Engine: 454
I want to temporarily disable knock control on my '91 Chevy Suburban.
Without burning a PROM, is there a way to feed a fake signal to the ECM so it won't set a knock sensor code?
I understand if I unplug the sensor a code will be set, as there is a load resistor inside the sensor to detect an open or a shorted knock signal.
I could defeat that test with a toggle switch and grounded resistor, but are there other conditions for which the ECM checks?
For example, I have read the ECM advances timing at some point to induce knock, then look for a knock pulse, or that it looks just looks for activity on the knock signal input.
Can anyone tell me how it really works and how I can fool it?
Old Mar 12, 2023 | 08:35 AM
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
Re: Knock Sensor codes on '91 Suburban
Deleted
Old Mar 12, 2023 | 08:43 AM
SbFormula's Avatar
Engine: LT1 6.2L
Axle/Gears: 3.91
Is it a 305 TBI?
Using a resistor jumper
Yes and timing will be retarded = lost of engine power
Yes, read your next point
Yes when ecm meets certain threshold for engine coolant, load and maybe speed.
I believe you need a chip burn to turn off ESC test but someone might chime in with a better solution.
Old Mar 12, 2023 | 10:42 AM
Car: 91 Suburban
Engine: 454
Thanks for your help. It's a 454 CID 3/4 ton R2500. California version.
Engine coolant temperature can be fooled so that might be an easy way, if indeed that is one of the factors.
Old Mar 12, 2023 | 11:09 AM
SbFormula's Avatar
Engine: LT1 6.2L
Axle/Gears: 3.91
Well, in fact I know nothing about big block 454 TBI. Might want to search other sites for Suburban as well.
EDITED: Your ecm should be 16147060 or 16127470 with a $85 mask. If you're ever interested in finding out your knock parameters.
http://www.gearhead-efi.com/Fuel-Inj...Information-85
Old Mar 12, 2023 | 11:21 AM
Car: 91 Suburban
Engine: 454
Source code with comments on operation would be nice.
Not looking to pirate code, just looking for a way to disable it externally.
Old Mar 12, 2023 | 11:23 AM
SbFormula's Avatar
Engine: LT1 6.2L
Axle/Gears: 3.91
Old Mar 12, 2023 | 12:18 PM
SbFormula's Avatar
Engine: LT1 6.2L
Axle/Gears: 3.91
If I may,
Problem is, you might fool the ecm for your knock sensor, but you will also fool it for a bunch of other things. Expect problems.
Old Mar 12, 2023 | 02:17 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Moved, not DIY_PROM related.
RBob.
Old Mar 13, 2023 | 05:20 AM
Car: 91 Suburban
Engine: 454
Thanks for the links. The forum requires me to sign up to read the files.
I tried to sign up over there but the forum won't send a link to confirm my email. I tried it from my desktop and my phone. I requested a password reset and it asks a random question, the answer to which can only be "LS1". On my desktop it says I gave the wrong answer, but it works on my phone. But it never sends a password reset email.
I'll have a friend try to register then send me the files.
Old Mar 13, 2023 | 07:56 AM
SbFormula's Avatar
Engine: LT1 6.2L
Axle/Gears: 3.91
; ERR 43 PARAM'S
; KNOCK DET ERROR
L85B3 FCB 20 ; TIME FOR VOTAGE OK TEST
L85B4 FCB 230 ; UPPER VDC THRESH, 4.6 VDC
L85B5 FCB 20 ; LOWER VDC THRESH, 0.4 VDC
L85B6 FDB 0010 ; 10 SEC PRIOR TO ERR 43 TEST
; (RESTART TME VAL)
L85B8 FCB 60 ; 60 SEC ENG RUN TIME PRIOR TEST
L85B9 FCB 23 ; 4 DEG SA REPLACES SKP RETARD VAL IF ERR 43
; (256/45) * SPK RESTARD VAL
L85BA FCB 10 ; 10 SEC TEST PERIOD FOR VOLTAGE, ERR 43
L85BB FCB 170 ; 87.5 Deg c COOL MIN FOR ERR 43 TEST
L85BC FCB 192 ; 104 Deg c COOL MAX FOR ERR 43 TEST
L85BD FCB 179 ; 69.9% TPS PWR ENR BYPASS ASSUM PWR ENR CONDITION
; IF TPS GT 99.6%
L85BE FCB 128 ; 3200 RPM UPPER LMT FOR ERR 43 TEST
L85BF FCB 195 ; 81 Kpa LOWER LMT FOR ERR 43 TEST
L85C0 FCB 46 ; 16.2 Deg SPK PWR ENR ADDED TO CAUSE KNOCK
; DEG SA * (256/90)
L85C1 FCB 91 ; 31.9 deg SPK PWR ENR ADDED TO CAUSE KNOCK IN
; 2nd MODE PWR ENR, (DEG SA * (256/90))
L85C2: FCB 2 ; 2 KNOCKS, KNOCK LMT MIN (12.5 Msec Period's)
; ERR 43 PARAM'S
; KNOCK DET ERROR
L85B3 FCB 160 ; TIME FOR VOTAGE OK TEST
; (RESTART TME VAL)
L85BA FCB 3 ; 3 sec TEST PERIOD FOR VOLTAGE
L85BD FCB 255 ; 99.6% TPS PWR ENR BYPASS ASSUM PWR ENR CONDITION
; IF TPS GT 99.6%
L85C0 FCB 34 ; 13.3 Deg SPK PWR ENR ADDED TO CAUSE KNOCK
; DEG SA * (256/90)
L85C1 FCB 68 ; 23.9 deg SPK PWR ENR ADDED TO CAUSE KNOCK IN
File Type: zip
Old Mar 13, 2023 | 07:59 AM
SbFormula's Avatar
Engine: LT1 6.2L
Axle/Gears: 3.91
IMO, your best bet is get a kit for chip burning and TunerPro software. I don't think there is anyway around it for what your are trying to achieve.
You need to change this for the maximum DegC allowable (151DegC I believe), so knock retard gets disabled:
L802C FCB 100 ; 35c, MIN COOL FOR KNOCK RETARD
; (Cal val = (DEG +40) * (256/192))
And also turn b4 to 0, so knock test won't occur.
L8577 FCB $3C ; 0011 1100, ERR FLG WD 4
; b7 = 1 = ERR 39, TCC STUCK OFF
; b6 = 1 = ERR 41, 1x CAM SENSOR FAIL
; b5 = 1 = ERR 42, SPK MONITOR
; b4 = 1 = ERR 43, KNOCK SENSOR
; b3 = 1 = ERR 44, o2 LOW
; b2 = 1 = ERR 45, o2 HI
; b1 = 1 = ERR 46, NOT USED
; b0 = 1 = ERR 47, NOT USED
Cheers!
Old Mar 13, 2023 | 11:59 AM
Car: 91 Suburban
Engine: 454
Thanks very much! I appreciate your help. I'll post results when or if I have any.
Old Mar 13, 2023 | 12:38 PM
SbFormula's Avatar
Engine: LT1 6.2L
Axle/Gears: 3.91
You’re welcome
m300slr
Sep 7, 2022 06:28 PM
rock861261
May 18, 2009 09:54 AM
Trickie
Sep 4, 2003 10:37 PM
88TAJeff
May 17, 2002 05:34 PM
breathment
Mar 26, 2002 05:28 PM
