will lt4 hot cam work in the zz4 conversion?
Old Jan 22, 2002 | 05:40 PM
86 sports coupe's Avatar
Car: 86 sports coupe-83 berlinetta
Engine: 5.0 in the sports coupe-350 in the berlinetta
Transmission: 700r4 in the sports coupe-turbo-350 with a 2500 stal in the berlinetta
Will the ecm and chip be compatible with the lt4 hot cam on the zz4 conversion?
Old Jan 22, 2002 | 08:15 PM
steve8586iroc's Avatar
86, I know this doesn't answer your question directly but it might get you going in the right direction. The only thing that the ecm controls is the idle and cruise circuit in the carb and ignition timing, maybe the egr, I think. If I were you I would ask this same question on the carb board. I bet someone over there is already running the same setup as you want to run.
Steve
Old Jan 23, 2002 | 10:22 AM
Thanks.
MustangBeater20
Oct 29, 2022 09:20 PM
italiano67
Dec 11, 2016 09:21 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
Fronzizzle
Aug 9, 2015 01:15 PM
anesthes
Aug 8, 2015 09:37 PM
