Can I use DFI?
Old Feb 9, 2002 | 06:53 PM
Black Knight's Avatar
Can I use DFI?
I am looking to buy this ACCEL DFI (model #74023) and the CAL MAP with software from a guy that was going to build an incredible 383 engine. He never finished his motor and as a result, never installed the DFI unit. As far as I can see, other than it being out of the box, this thing is new. The guy never installed the DFI unit. The price of this DFI is $800 .
I think this package sells for a little over $1,200 new. Am I correct? Is $800 a good price
Can I use this to corvert the Mass Air System in my GTA when I do my 383 or 406 buildup or do I just need a piggyback system?
Thanx
Old Feb 10, 2002 | 08:29 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
Unless it comes with all the sensors, $800 is not that great a deal, but it is ok. That's what I spent when I bought mine a few years ago, Calmap included. The Accel unit does use a MAP sensor, so you'd have to convert from Speed Density (MAF). No piggy-back required.
Old Feb 10, 2002 | 09:04 AM
Thanx RCR. I have attached a picture (hopefully). It does come with all the sensors and it does convert from MAF to Speed density I believe
Would it be easier just to use a piggyback system?
Old Feb 10, 2002 | 10:56 PM
Earl 87gta's Avatar
You can get a dfi ecu for 725 and have your harness rewired to work with it for 100 thats 825 only hing is you will have to bum a copy of the calmap soft ware from some one or buy it.
Old Feb 11, 2002 | 10:50 AM
RCR's Avatar
RCR
That looks like the complete setup sold be Jegs or Summit. I'd say it was worth the money. It will make your system SD. You will also have to repin the harness or find an adapter.
Old Feb 11, 2002 | 03:26 PM
Thanx Earl and RCR.
Another question, should I wait and use the Gen 7 system which is windows based? Is the only difference the software?
Earl
Where can I get my harness rewired? Can I get the ECU with Gen 7 software?
Old Feb 11, 2002 | 03:42 PM
RCR's Avatar
RCR
The Gen7 offers more features and better control. Exact differences, I'm not sure, but I'm sure it's more expensive.
Old Feb 11, 2002 | 10:49 PM
Thanx again for the input RCR.
I went onto summit's website and put in the accel part number and the price was a little over $900, but they were back ordered. I think I will have to give Fast Track a call and see if they have Gen 7 and how much it will cost.
Old Feb 12, 2002 | 02:41 AM
89ProchargedROC's Avatar
i'll sell you mine for $700
AND
throw in my plug-n-play harness for nothing (cost me $175)
basically what it does is allow you to keep EVERYTHING that the normal computer controls like:
-speedo
-cruise control
-a/c
-torque converter lockup
-ESC (electronic spark control)
Here is a pic of the plug-n-play harness, it works for cars originally equipped with MAFS, let me know if you are interested:
Old Feb 12, 2002 | 07:40 AM
89ProchargedROC
Does your setup convert the car from MAFS to speed density? IS it a gen 7 version?
Thanx
Old Feb 12, 2002 | 01:18 PM
yes it converts MAF car to speed density
no it is not the gen 7 version. The gen 7 version is BRAND NEW and costs OVER $2200 right now
JUST FOR SOFTWARE AND THE COMPUTER!
Old Feb 13, 2002 | 12:24 PM
LIL QIK's Avatar
Yea, but thats with the wide band 02 sensor. And unfortunately I haven't found a piggy back that will work with a Gen 7 or a Wide Band.
Old Feb 13, 2002 | 12:39 PM
i dont like the gen VII DFI
FAST is a better choice IMHO
you can get a piggy pack plug n play harness for them and also have the wideband for like $2500 total through www.fasttrackperfomance.com
it might even be lower
Old Feb 13, 2002 | 12:42 PM
LIL QIK's Avatar
So your saying it will piggy back my factory harness and get the wideband...........That's what I need.........is this the speed pro or dfi or what? And thanks for the link.
Old Feb 13, 2002 | 01:15 PM
89ProchargedROC is right. I talked to fasttrack also. It will piggyback your factory harness and it is speedpro, not Accel DFI.
Old Feb 13, 2002 | 01:23 PM
LIL QIK's Avatar
Would anyone happen to have the part# for the setup.....piggyback and speed-pro ecu. Now I just have to figure out how to get rid of the DFI. I've always heard the speed pro was easier but I heard it after I bought two of the DFI's. Thanks for any help. I'm assuming it would be easier to tune the twin turbo with the speed pro.
Old Feb 15, 2002 | 11:10 PM
flyboydave's Avatar
I just bought a used DFI setup for $500 including the main harness and injector harness. It has the programming cable, but not the software. Also, no manual. Anyone know where I could get a copy of the manual on the net?
Old Feb 16, 2002 | 02:51 AM
i sent you an email
Old Feb 17, 2002 | 05:25 PM
RCR's Avatar
RCR
You can try this over at www.cruzinperformance.com : http://www.cruzinperformance.com/accel/
efiguy
Sep 27, 2015 01:30 PM
e3pres
Sep 9, 2015 01:51 PM
marcusaw
Aug 10, 2015 08:13 AM
manuel
Aug 19, 2001 10:29 AM
