115mph shutdown chip override?
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i gotta friend with a 1990 camaro
it has a speed chip where it wont go over 115
i was wondering if there is anything he could do to override this chip or something......thanks
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Ain't that a bitch!!!!!
his 90 camaro is a 305 TBI right?it's the VSS that wont allow him to go any faster than that.there are ways around it with out burning a new chip.just do a search the VSS.
Car: Death Mobile
Engine: 666 c.i.
Re: Ain't that a bitch!!!!!
Do it right, remove the speed limiter in the eprom. If you get the eprom burning equipment and spend a little time with it you'll get even better performance and better gas mileage that while more than offset the cost.
If you want to make a "short-term cheap decision" (which will cost you in the long run) just contact a custom eprom burner like Ed Wright to remove the speed limiter. Some of the "off-the-shelf" may also remove the speed limiter.
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
