still can not get CM to link?
Old May 2, 2002 | 12:36 AM
IROCBlueZ28's Avatar
I just got my new cable with the power supply and I can not link to Craig Moates software??? Connections are good and correct, black to black, red to orange as stated in the instructions. I am running Windows ME and booted to dos and opened the program from the C:\ but still could not get the program to link? Any help would greatly be appriciated! I am going to format the HDD and install W98 tomorrow and give it a go? I have my lpt on com 1 and can not change that, but i set the software to use com2 and I the cable is connected to com 2.???? PLEASE HELP
Old May 2, 2002 | 07:04 AM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Get back once you've tried the Win98 thing. You know you can just download a boot disk and run the program from a floppy to try it out...Datalogging would be a bit limited though!
LPT on COM1? I'd not heard of that. Guess I haven't lived.
Old May 6, 2002 | 07:13 PM
OK, I have installed W98 on my thinkpad. I also have w98 on my friends dell laptop, have the ecm850 program installed in both laptops and i can not connect or LINK up to the ALDL??? I thought it may be a conflict between the com ports, however, i disabled the IR on my Thinkpad and was able to remove the lpt port so the com 1 was avaliable by itself on the dell. I can not link up to the car with either laptops? I click on the startrun and the proram seems to work in "off line mode" but does not work at all in diagnostic mode?
Can anyone help
Old May 7, 2002 | 12:46 PM
H E L P...............ANYONE?
Old May 8, 2002 | 12:30 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I believe I am still using the version 8.45 but I will have to check when I get home. But, AFAIK, you shouldn't be having this problem.
What cable are you using?
Try running through all of the diagnostics here: http://www.akmcables.com/serial.doc
Old May 8, 2002 | 12:38 PM
I just got my Max 232 with the power supply from steve ruse. I am using both, versions; 845 and/or 850???
Old May 8, 2002 | 04:34 PM
I"m a linking!:hail: Had to disable the IR port and changed the com from 1 to 2.
Old May 8, 2002 | 07:57 PM
Matt87GTA's Avatar
Cool. Good to hear .
Old May 8, 2002 | 07:59 PM
Yea! I have diacom, but it seems like the CM is much better. We will see the more i get to play with it!
Old May 9, 2002 | 12:56 AM
Car: 87 T/A
Good to hear you've got it up. I've seen that exact problem before...
Fanatic1074
Oct 3, 2022 05:57 AM
3rd gen money
Oct 11, 2019 09:57 PM
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
