Once I start prom ING can a cam with a 110 centerline be edited into my chip?
Old May 8, 2002 | 06:40 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
Once a person becomes very good at programming chips, is it possible to make enough mods in the computer to use a big (high duration/high lift )cam with a 110 or lower center line?
Old May 8, 2002 | 09:36 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Yes.
Tim
Old May 9, 2002 | 02:17 AM
RedIrocZ-28's Avatar
Car: Iroc-Z
Engine: 355 AFR'd HSR
Thank ***! I was having doubts as to whether my 110* LSA cam was too little of an LSA to be able to be tuned correctly.
Ya know, my problems with my car are going to be a bit different than other people's since my motor is modded internally i.e. 10.3:1 Compression and a much larger cam. The thing is I am kinda leary of asking questions because I will get the "Use the search button" reply.... I am sure that MY question hasn't been asked yet! lol... Oh well I guess you and I are in the same boat here, maybe we should stick together on this one?
Old May 9, 2002 | 07:56 AM
TRAXION's Avatar
rotflmfao ... trust me - you and I are NOT in the same boat. You are in a canoe just learning how to paddle and I am in a speedboat with dual chevy big blocks
Tim
Old May 9, 2002 | 12:28 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
:sillylol:
C'mon now Trax, you were a newbie once too... a long, long time ago in a land far, far away....
Old May 9, 2002 | 02:56 PM
86Tra/maro's Avatar
Guys,
I think that he means 86tramaro & himself are in the same boat.
njdaewoo
Old May 9, 2002 | 05:52 PM
AlexJH's Avatar
Engine: 5.7L V8
I did some searching on the GMECM lists and those guys went as high as 234/234 I think. But those are the guru's. I'm going with a 224/224 cam with a 108 LCA.
Old May 9, 2002 | 10:58 PM
86Tra/maro's Avatar
Thanx for the replies.
njdaewoo
Old May 9, 2002 | 10:59 PM
86Tra/maro's Avatar
Do U guys think that I can use the 219Dur. Lingenfelter cam with a Stealth Ram?
Old May 10, 2002 | 02:51 AM
Car: Iroc-Z
TRAXION, I was not referring to YOU and I.. lol!!! Dude, I am not even in a canoe... I am in some leaky *** reed boat made 3000 years ago..I am sinking... I was refering to 86tramaro or however you spell it.
Old May 10, 2002 | 12:31 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
I hope so, I'm putting a 224 duration on mine.
Old May 12, 2002 | 11:34 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I passed emmisions with the LPE 219 cam, and it runs fine.
My next cam will be a cam motion 235-239 .601-.604 lift on a 114 lsa.
Old May 13, 2002 | 09:06 AM
86Tra/maro's Avatar
89GTa383,
Can u please tell me if that 219 LPE cam's as strong as they say it is?
Old May 13, 2002 | 09:13 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Yup. It pulls strong to 62-6300 in my setup.
I've been running cam combos for my new setup and the 219 cam beats most cams out there in avg hp and avg tq, plus cylinder pressure, and vacuum. It idles well, with no lope in my motor.
The only problem is the damn price. If you can pick up a used one like I did, then it's well worth it.
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
NWAsonoma
Aug 18, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
