LG4 chip
Old Jun 1, 2002 | 10:06 AM
BuddyLeeX's Avatar
Car: 06 Toyota Tundra SR5
LG4 chip
ok, i took out the stock chip and on my jet chip, it doesnt say which way to put it in, so i just put it in whichever way. But, I disconnected the negative to the battery cause i thought it needed to reset, plugged it abck up. Then started it up and the "service engine light coems on". Did i put the chip in wrong, or do i need to disconnect the negative to the batttery longeR? Please help, thanks,.
Old Jun 9, 2002 | 02:58 PM
jeffs82z28's Avatar
if you plugged it in the wrong way it will through a code, I believe a 51, pull the codes using the aldl and see what code it is throwing.
If it is a 51, you probably installed the calibration chip in backwards, and most likely it is cooked, but you could try to re-install it correctly.
The chips have an indentation/orientation mark on one end and it has to be installed in the ecm pointing in the right direction. (I don't know which way)
Standard disclaimer: Just my .02
Old Jun 10, 2002 | 08:37 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Exactly. Look at one end of the eprom and you will see the "notch". Unfortunately, I don't have an LG4 and I can't tell you which direction the eprom should be in (since you probably don't recall which way it came out).
My suggestion is to switch the eprom around to see if it works.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
