A chip to pass emissions
Old Jun 5, 2002 | 02:59 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
My emissions test is coming up and I want to burn a chip to put in just for the emissions test. Can anyone tell me what I can change to help my car run cleaner? Like what should I do the timing tables? I don’t care if my car runs really slow with this chip. I just need it to pass.
Old Jun 5, 2002 | 03:15 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: A chip to pass emissions
If you've done your chip right, it should pass.
If in doubt, then use a stock .bin file.
Fresh oil change.
As hgh as idle as possible.
Hot thermostat,
are also good ideas.
Old Jun 5, 2002 | 04:28 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
Its also a good idea to back off the base timing.
Old Jun 5, 2002 | 08:54 PM
kvu's Avatar
kvu
What worked for me:Leaning the inj constant,raise the tps% for pe,locked up the torque converter at the stock mph high and low,195tstat and of course a tuneup/oilchange/iac reset.I have a "dyno" type emissions though.If it's the idle type of test the latest chip you have should do.Unless your smoking most cars will pass the idle test w/o cats(I have mine).Those methods got me lower emissions than my sisters tercel.It worked for me but it's not a blueprint.Grumpy is right,it should pass if your chip is close.I just did all that stuff so I would'nt have to go back.If it did fail they would look under the hood.Then I would have had to explain the air inj delete option my car came with . For the most part the air injection seems like a fail attempt at lowering emissions.A dinosaur of the 80's.Hell I dont know but thats what I did.
gta892000
Aug 11, 2019 11:16 AM
Johnny*G
Oct 20, 2015 12:37 PM
ramicio
Sep 28, 2015 01:18 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
TBRays98
Sep 6, 2015 05:05 PM
