GN fan switch
Old Jun 7, 2002 | 08:57 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
GN fan switch
Ig have what i believe to be a gn coolant fan switch? question i have is is it the one that goes on the driver head or the pass head? also does it have the slide on top connector vs. the push on type? just making sure i have the right part my tta unfortuneately is still in storage and my formie now hs the engine pulled out :-(im not having good luck)
please let me know
thanks
Old Jun 8, 2002 | 08:16 AM
3.8TransAM's Avatar
well i havent managed to figure it out yet so if u know please respond? grumpy u use it dont u?
Old Jun 8, 2002 | 09:46 AM
kvu's Avatar
kvu
sounds like a cooant temp sensor.I'm fairly sure gm made the plug type conector on all gm cooling fan switches.
Old Jun 8, 2002 | 10:08 AM
3.8TransAM's Avatar
thanks thats what i was thinkin too but since once is torn down and the other one in storage im kinda sol at the moment .....
and i dont havr a car available to me all the time :-(
son very soon the formie will arise and once it does the tta goes under the knife /(stock of course)
Old Jun 8, 2002 | 10:14 AM
kvu's Avatar
kvu
The cooling fan switch usually is on the pass side head towards the back.If your not sure just ground the wire to the switch w/ key on .If its the right one the fan will kick on.The wire to the cooling fan should be green w/white stipe i think.
Old Jun 8, 2002 | 11:27 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: GN fan switch
If it has a single pin cinnector, like the Knock Sensor, it's a fan switch.
I generally mount it by the thermostat (engine side of the thermostat).
GN on temp is 205dF
Old Jun 8, 2002 | 11:31 AM
3.8TransAM's Avatar
guess im outta luck then it looks like the temp sensor for the guages in the drvr cyl head ....wish my luck would change lol
would be nice
thanks grumpy
Old Jun 8, 2002 | 01:00 PM
kvu's Avatar
kvu
ops
Old Jun 13, 2002 | 11:45 AM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
do you have the part # for the gn fan switch????
Old Jun 14, 2002 | 04:24 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
The one I bought was from Autozone... Wells part number SW555.
Old Jun 14, 2002 | 05:46 PM
leirch's Avatar
MikeH,
Have you verified the temperature that switch turns the fan on? I have a fan switch from a "GN" but it wont' turn the fan on until 230degrees.
-Brendan
Old Jun 14, 2002 | 06:29 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Originally posted by leirch
MikeH,
-Brendan
That's a universal replacement, some bean counters, idea of this is close enough.
Standard Brand Ignition parts shows a TS-136 as having a 204-220 close temp..
Hate to even mention them but Hypertech has some fan switches of lower operating temps.
Old Jun 14, 2002 | 06:36 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Yes...my scanner shows 208* when the second fan kicks on.
Old Jun 17, 2002 | 11:01 AM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
will this switch work on a 92 z28?? the ts-136 that is.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
