305 and 350 memcals same? Not proms
Old Jul 4, 2002 | 08:48 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I want to know if the memcals are the same for a 305 and 350 from a '90-92 speed density setup.
I know the programming is differant, not worried there.
I just want to know if the basic memcal is the same between the two. I can't tell by GM part number because the have differant broadcast codes so the p/n's will be differant.
I am concerned because the EST circuits are in the memcal.
Thanks!
Old Jul 5, 2002 | 08:39 AM
leirch's Avatar
Yep, the memcals are basically the knock sensors also so they are different from 305 to 350.
Old Jul 5, 2002 | 11:44 AM
Engine: 4.0L
A memcal is a knock sensor?
I ask because my friend has a 305 memcal (home burned prom) in his 355 engine, it does not set any codes like a wrong knock sensor.
The question is still open, are 305 and 350 memcals ('730 ECM) the same minus the program in the chip??
Old Jul 6, 2002 | 08:22 AM
Engine: 4.0L
50 views and no-one?
I of course searched and found nothing. I know many people have swapped from 5.0 to 5.7, did you just do a reburn of the prom or buy a new one?
Knock sensors are differant and I imagine the EST circuitry inside the memcal would be differant as well.
Old Jul 6, 2002 | 11:43 AM
Team FTS's Avatar
Yes the Memcals are different
From Traxion's article:
The limp home mode chips (netres, short for network resistors) and possibly the ESC Filter ('90-'92 TPI F-Bodies, aka Knock Module) are different for the 305 and 350 and these are located in the Memcal.
Old Jul 6, 2002 | 01:13 PM
Engine: 4.0L
Thanks so much. I must have read that thing a dozen times last year but didn't remember seeing it there (the answer).
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
