SD conversion VSS edit in prom
Old Jul 5, 2002 | 11:50 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Okay so today I am undertaking my speed density conversion. I am currently repining the harness. I already mounted the MAP. I bought an AUJP memcal. I have read that I need to edit the bin for the old style VSS. One site that I was reading about the conversion said "requires PROM change. Mag. VSS at 0x18 b6 for $8D PROMS". So what do I have to change at 0x18? Can I do this with a hex editor?
Old Jul 5, 2002 | 12:06 PM
kevinc's Avatar
Car: 1982 Z28
This change is easily made with GMEPro or TunerCat, probably with WinBin also.
You'll be tweaking more than just the VSS input param so jump into a tuning app and get it over with. Doing it all with a hex editor is probably possible, but a huge waste of time.
Old Jul 5, 2002 | 12:55 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Oh so it's one of the ECM switches that has to be chaned for the VSS. I though you had to make a edit to the code for the VSS. So which switches do i change in Tunnercat?
Old Jul 5, 2002 | 04:15 PM
kevinc's Avatar
Car: 1982 Z28
Under the ECM Switches menu, scroll down to "Magnetic Speed Sensor Installed" and set it to no (unchecked). This sets it to look for a 2000 pulse/mile input signal, typical of the optical VSS unit in older cars.
Linson
Oct 24, 2025 02:00 PM
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
dusterbd
Sep 29, 2015 08:40 AM
