What are your maximum map readings?
Old Jul 23, 2002 | 10:51 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Will your engine actually pull 100 percent of the value of the barometric pressure under WOT? Say I flip my key on w/o starting the engine and my map KPa is 99.16. How close can an engine get to zero pressure inside the intake? Does this represent an intake restriction?
Old Jul 23, 2002 | 02:49 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: What are your maximum map readings?
Intake tract, cam, exhaust all play huge roles.
Takes alot of work to get to near 0.
I've had a car that was steadily 96s, with a mild cam.
You can trick and engine with plenum volume, and runners, but it's just as good to not worry about the MAP as much as ET.
Old Jul 23, 2002 | 03:54 PM
Car: 1991 Firebird
Engine: 427 LSX
Wise words. Thank you.
Old Jul 24, 2002 | 12:05 AM
funstick's Avatar
i ve seen as high as 100 kpa and 4.7 volts in a boat. naturally aspirated of course.
Old Jul 24, 2002 | 09:58 AM
Car: 1991 Firebird
Engine: 427 LSX
What was the atmospheric pressure that day? couldn't have been 100kpa?
Old Jul 24, 2002 | 11:22 AM
funstick's Avatar
i dont rememeber. the boat had a Tunnel ram intake. this period of map reading is very breif for about 1500 rpm of the power band. it start at 3500 and continues to 5000 rpm. tunnels rams have the ability to create inertial supercharging.
Old Jul 24, 2002 | 08:02 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I find the kpa rating while in WOT is about 2 kpa less than the kpa reading if I have my scan tool running and JUST turn off my engine.
EG. On the WestCoast, at sea level. The MAP sensor reads 102 kpa when I turn off the engine (and leave the scan tool running). While in WOT I never get over 100.
At Kamloops, where I currently live, I usually read 97-98 kpa on the "flats" (depending on weather) with the engine turned off. But in WOT I get 95-96 kpa.
So I get a consistent 2 kpa difference between WOT and a "turned off engine".
Old Jul 25, 2002 | 08:35 AM
Car: 1991 Firebird
Engine: 427 LSX
So the west coast has more pressure. My car would run faster there?
Old Jul 25, 2002 | 07:26 PM
Car: Death Mobile
Engine: 666 c.i.
It has more pressure because it's at sea level. The higher you go (elevation) the less the maximum MAP reading.
Bubbajones_ya
Jul 6, 2024 08:32 PM
TrevinE
Sep 14, 2015 03:20 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
86IROC112
Sep 11, 2015 04:04 PM
Street Lethal
Sep 7, 2015 01:09 PM
