747 ESC test patch...
Old Jul 31, 2002 | 02:05 AM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I just patched my current bin with RBobs "ESC test complete" patch.
I kinda expected the "ESC ready for 2nd power enrich" flag to be on all the time, but it's not. Will it ever come on?
Just curious what I should be looking for, if anything. Or do I just sit back and enjoy PE SA the first time I go to WOT?
Old Jul 31, 2002 | 08:02 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 747 ESC test patch...
Don't think that flag will ever be set. The patch sets the ESC test
completed successfully flag. That and it bypasses the PE delay
quals.
The ECM will now deliver PE & hiway SA right from the get-go.
RBob.
Old Jul 31, 2002 | 11:22 AM
Car: Bee-Bowdy
Axle/Gears: fo-tins
Thanks again
Old Jul 31, 2002 | 01:26 PM
JPrevost's Avatar
Car: 91 Red Sled
What is the point of the patch if you can just disable both the delay and the EST (knock also) tests with simple switchs. Or does the ecm require that the test be completed before any PE SA etc.?
Old Jul 31, 2002 | 05:29 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
I think the first time the ECM goes into PE mode it keeps advancing the timing until it detects knock, then retards the timing accordingly. I also seem to remember that you will not get any PE SA until this test has been passed.
As RBob said, it's sort of a crappy way of doing it.
This way WinALDL won't record the knock performed by the ESC test. And I won't turn the timing down in places that are not trouble spots.
Old Feb 16, 2003 | 09:47 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
I know this is an old post, but is this patch available @ diy-efi.org??
Old Feb 17, 2003 | 04:33 AM
Car: Bee-Bowdy
Axle/Gears: fo-tins
here it is
File Type: zip
Old Feb 17, 2003 | 08:56 AM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Thanks!
Linson
Oct 24, 2025 02:00 PM
RedLeader289
May 28, 2019 01:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Eric-86sc
Sep 28, 2015 11:37 AM
