Wide band O2 questions
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
Where do you guys get these WB O2's? Where/how do you plug them into the exhaust? Do they replace the stock O2 or are they in addition to it?
Car: An Ol Buick
Engine: Vsick
Re: Wide band O2 questions
WWW.DIY-WB.COM
Uses a Honda Sensor, that goes for about $130.
Going the DIY route you can get out for well under $200 including a slick display.
EFI Systems in GA has one that's just now available for $550 including sensor.
You have to add a bung to the exhaust, or go open loop and use the NB mounting. An 18mm anti-fouler makes a good source for the bung, but it takes some hacsaw work to get it to work.
Car: 89 formula
Engine: 383
How about these wide band sensors http://interstice.com/~garfield/ http://www.lambdaboy.com/ http://www.fjoinc.com/automotive/products.htm The FJO is nice because you could get it with the RPM read out making it easyer to tune but its $$$ and the EGOR also has narrow-band O2 sensor simulated output for stoich crossing at a decent price.
Car: An Ol Buick
Engine: Vsick
Originally posted by GofasterFirebird
Could I shove a WB in the rear tailpipe? I have seen cars on dynos like this.
I use a tailpipe probe when a bung ain't available. But the delay is noticeable, when your doing transistional tuning.
N there can be a slight error when using real long cables.
Car: An Ol Buick
Engine: Vsick
Try WWW.DIY-WB.COM
Me? it was worth playing around rather then playing $500 for $20 worth of electronics.
If you want to spend money get the good stuff from firms like NTK Bailey or Horiba.
The DIY WB works great. I can vouch for that, I went down to Grumpy's and picked a extra board up and then contacted Bruce Roe to get one of his LED PCB boards. Its very slick. I had an extra O2 bung welded in right before my cat and have the wires ran into my door.
Brendan
Brendan
does it really take 40 seconds for the WB O2 sensor to warm up?? My car is my daily driver, and I dont know if I would want to wait 40 seconds every time I start my car.. Guess it would be best to take it out when not in use, and plug up the bung..
-Mark
-Mark
Car: check
Engine: check
Transmission: check
-Mark
-Mark
If I want to check the startup AFR's I turn on the ignition and wait. Then start the engine. Other then that I just start and go.
RBob.
Car: check
Engine: check
Transmission: check
humm.. thats strange.. on diy-wb.com, they say you cant start the car before the sensor heats up, otherwise you will do damage to the sensor.
-Mark
-Mark
What is true is that running the engine without the heater powered up will ruin the sensor. As long as the controller is supplying power to the heater it is all OK.
RBob.
amargari
Nov 10, 2015 02:09 PM
