WinXP and PP don't mix
Car: RS
Axle/Gears: 9" for the ladies
Get a "privileged instruction" error when trying to run the PP software. I went to xtronics website and it looks like they have an upgrade but they ask for a password. Did you guys all get passwords or something with your PP, because I didn't so is this a new thing?
Kind of a big FU for some of there older customers I think.
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
I had some problem with that, but looks like it's working now. Every now & then it does that, don't know why.
Check your Windows/system directory and make sure you have 'ntport' and 'zntport' present. This seemed to be an issue early in the exercise.
Make sure you don't have anything conflicting (ie. port management software running in the background)...
Car: RS
Thanks for the help Craig. Seems its still doing it though.
xtronics tells me to buy a $50 update. They don't even say it will fix my problem. Wonder how long Mcafee and other companies would stay in business if they charged for every update, when their software wasn't compatible.
Car: 91 Red Sled
You should think about a dual boot OS. Have win98 and winxp. It's an easy solution but to soom it's too much trouble to sit and wait for an older OS to load all of it's drivers
. Supreme Member
Car: 04 GTO
Transmission: M12 T56
Never had a problem from day one running my PP from XP. I forget which version of the software i'm running, but it's at least last january old...
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
Aaron, I am having the same problem as well. I can't believe xtronics is charging for another upgrade! I already bought the windows upgrade from them and correct me if am wrong but we are still running windows, just a different version.
Car: 87 T/A
We (the DIY community) will be moving to a different vendor for the chip programmer. I'll keep everyone posted.
i am moving from the epromer4 to the epromer5 the windows software is easy and they are adding support for flash as we speak. anfor about a $100 dollars its the best deal going with the free software updates and all.
Car: RS
Figured out it was for sure that you had to update the software.
Of course they orginally wanted $50 for this. Yeah right!
www.ustr.net epromer5 programs 5 12 21 and 25 volts chips. flash is comming.
